Pokaż wyniki od 31 do 45 z 45
Wątek: Skan błędów - Audi TT 180KM
Widok wątkowy
    Dec 2010
    Czarna
    87
    Dzisiaj zrobiłem pierwszy skan błędów, pokazało mi takie błędy:
    VAG-COM Version: Release 409.1-S
    Chassis Type: 8N - Audi TT
    Address 01: Engine
    Controller: 8N0 906 018 A
    Component: 1.8L R4 5VT 0010
    Coding: 05500
    Shop #: WSC 01236
    4 Faults Found:
    16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
    P0134 - 35-00 - -
    17524 - Oxygen (Lambda) Sensor Heating: B1 S1: Open Circuit
    P1116 - 35-00 - -
    17964 - Charge Pressure Control: Negative Deviation
    P1556 - 35-10 - - - Intermittent
    16502 - Engine Coolant Temp. Sensor (G62): Signal too High
    P0118 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes
    Controller: 8N0 907 379
    Component: ASR 20 IE CAN 0001
    Coding: 13204
    Shop #: WSC 01236
    No fault code found.
    Address 08: Auto HVAC
    Controller: 8N0 820 043
    Component: TT-KLIMAVOLLAUTOMAT D02
    Coding: 00040
    Shop #: WSC 01236
    4 Faults Found:
    00603 - Footwell/defroster Flap Positioning Motor (V85)
    41-10 - Blocked or No Voltage - Intermittent
    00797 - Sunlight Photo Sensor (G107)
    30-10 - Open or Short to B+ - Intermittent
    01206 - Signal for Duration of Ignition: OFF
    01582 - Signal for Coolant Temperature
    Skipping Address 15-Airbags
    Address 17: Instruments
    Controller: 8N1 919 860 C
    Component: KOMBI+WEGFAHRS. M73 D29
    Coding: 00144
    Shop #: WSC 02082
    Ident.-Nr. Wegfahrs.:AUZ5Z0C2075039
    1 Fault Found:
    00779 - Outside Air Temp Sensor (G17)
    30-00 - Open or Short to B+
    Address 35: Centr. Locks
    Controller: 8N8 962 267
    Component: Zentralverrieg.,DWA D04
    Coding: 04682
    Shop #: WSC 01236
    6 Faults Found:
    35-00 - -
    35-00 - -
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    36-10 - Open Circuit - Intermittent
    00956 - Key 2
    Address 45: Inter. Monitor
    Controller: 8N8 951 177
    Component: Innenraumueberw. D09
    Coding: 00001
    Shop #: WSC 00000
    End --------------------------------------------------------------------------------------------------
    Po skasowaniu został tylko jeden błąd, mianowicie czego on dotyczy, z tego co widze jest to błąd spowodowany wybiciem poduszki bocznej od strony kierowcy, czy dotyczy on tego sensora?
    Control Module Part Number: 8N8 909 601
    Component and/or Version: Airbag Front+Seite 0005
    Software Coding: 10102
    Work Shop Code: WSC 09515
    1 Fault Found:
    00654 - Seat Belt Tensioner Igniter: Driver Side (N153)
    32-00 - Resistance too High
    Raz się też pojawiły te 2 błędy, ale skasowałem ponownie i już tego błędu nie ma, jeśli powróci to dam znać, ale czy to coś poważnego:
    Control Module Part Number: 8N0 906 018 A
    Component and/or Version: 1.8L R4 5VT 0010
    Software Coding: 05500
    Work Shop Code: WSC 01236
    2 Faults Found:
    P1116 - 35-00 - -
    Ostatnio edytowane przez w0jt4k ; 07-04-2011 o 17:55
  1. Pomocy ! Pierwszy skan i tyle błędów co robić :/
    Ostatni post / autor: 04-12-2015, 10:12
  2. Pierwszy skan - pomoc z analizą błędów
    Odpowiedzi: 19
    Ostatni post / autor: 27-01-2015, 16:51
  3. PawelM skan błędów - tylko 1 :)
    Przez PawelM w dziale MK1 (1998-2006)
    Ostatni post / autor: 30-01-2012, 10:51
  4. pierwszy skan błędów
    Przez ziembol89 w dziale VAG-COM
    Ostatni post / autor: 27-01-2012, 13:15
  5. Audi TT 180KM vs Mercedes W211 E270 180KM
    Przez Chmoora w dziale Kill on street
    Ostatni post / autor: 04-02-2009, 21:38
