Pokaż wyniki od 1 do 15 z 45
Wątek: Skan błędów - Audi TT 180KM
    Dec 2010
    Czarna
    87
    Dzisiaj zrobiłem pierwszy skan błędów, pokazało mi takie błędy:
    VAG-COM Version: Release 409.1-S
    Chassis Type: 8N - Audi TT
    Address 01: Engine
    Controller: 8N0 906 018 A
    Component: 1.8L R4 5VT 0010
    Coding: 05500
    Shop #: WSC 01236
    4 Faults Found:
    16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
    P0134 - 35-00 - -
    17524 - Oxygen (Lambda) Sensor Heating: B1 S1: Open Circuit
    P1116 - 35-00 - -
    17964 - Charge Pressure Control: Negative Deviation
    P1556 - 35-10 - - - Intermittent
    16502 - Engine Coolant Temp. Sensor (G62): Signal too High
    P0118 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes
    Controller: 8N0 907 379
    Component: ASR 20 IE CAN 0001
    Coding: 13204
    Shop #: WSC 01236
    No fault code found.
    Address 08: Auto HVAC
    Controller: 8N0 820 043
    Component: TT-KLIMAVOLLAUTOMAT D02
    Coding: 00040
    Shop #: WSC 01236
    4 Faults Found:
    00603 - Footwell/defroster Flap Positioning Motor (V85)
    41-10 - Blocked or No Voltage - Intermittent
    00797 - Sunlight Photo Sensor (G107)
    30-10 - Open or Short to B+ - Intermittent
    01206 - Signal for Duration of Ignition: OFF
    01582 - Signal for Coolant Temperature
    Skipping Address 15-Airbags
    Address 17: Instruments
    Controller: 8N1 919 860 C
    Component: KOMBI+WEGFAHRS. M73 D29
    Coding: 00144
    Shop #: WSC 02082
    Ident.-Nr. Wegfahrs.:AUZ5Z0C2075039
    1 Fault Found:
    00779 - Outside Air Temp Sensor (G17)
    30-00 - Open or Short to B+
    Address 35: Centr. Locks
    Controller: 8N8 962 267
    Component: Zentralverrieg.,DWA D04
    Coding: 04682
    Shop #: WSC 01236
    6 Faults Found:
    35-00 - -
    35-00 - -
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    36-10 - Open Circuit - Intermittent
    00956 - Key 2
    Address 45: Inter. Monitor
    Controller: 8N8 951 177
    Component: Innenraumueberw. D09
    Coding: 00001
    Shop #: WSC 00000
    End --------------------------------------------------------------------------------------------------
    Po skasowaniu został tylko jeden błąd, mianowicie czego on dotyczy, z tego co widze jest to błąd spowodowany wybiciem poduszki bocznej od strony kierowcy, czy dotyczy on tego sensora?
    Control Module Part Number: 8N8 909 601
    Component and/or Version: Airbag Front+Seite 0005
    Software Coding: 10102
    Work Shop Code: WSC 09515
    1 Fault Found:
    00654 - Seat Belt Tensioner Igniter: Driver Side (N153)
    32-00 - Resistance too High
    Raz się też pojawiły te 2 błędy, ale skasowałem ponownie i już tego błędu nie ma, jeśli powróci to dam znać, ale czy to coś poważnego:
    Control Module Part Number: 8N0 906 018 A
    Component and/or Version: 1.8L R4 5VT 0010
    Software Coding: 05500
    Work Shop Code: WSC 01236
    2 Faults Found:
    P1116 - 35-00 - -
    Ostatnio edytowane przez w0jt4k ; 07-04-2011 o 17:55
    chyba ci sie troszke pomylilo to nie logi tylko lista bledow z auto scana
    zapraszam do lektorki http://www.klubtt.pl/vag-com/3335-za...styka-vag.html
    Pokazało się kilka niepokojących błędów i zanim zaczniemy je po kolei opisywać to sprawdź czy i które powrócą po przejechaniu ok 60-100 km
    No i fakt , skan na błędy to nie logi
    Dec 2010
    Czarna
    87
    Jestem w tym nowy, więc proszę o zrozumienie.
    Jak na razie powrócił ten błąd:
    P1116 - 35-00 - -
    Cytat Zamieszczone przez w0jt4k Zobacz posta
    Sonda lambda do wymiany?
    Awatar wowo
    4xx
    1,251
    Coś nie tak z grzałka sondy. Mozesz sprawdzić polączenia, ale bardzo mozliwe ze grzałka po prostu padła - sonda do wymiany. Na zagrzanym silniku powinna działac normalnie, ale podczas pierwszych minut pracy, moga dziać się cuda.
    Dec 2010
    Czarna
    87
    No właśnie po skasowaniu błędów silnik zaczął chodzić dziwnie, gdy odpalam czasem to zdarza się, że zgaśnie, muszę dać trochę gazu i po kilku s. zaczyna trzymać obroty, ale silnik chodzi dziwinie trochę, obroty delikatnie skaczą.
    Może być taka:
    ! AUDI A4 A6 TT SKODA OCTAVIA VW GOLF SONDA LAMBDA (1545853609) - Aukcje internetowe Allegro
    lub taka:
    http://allegro.pl/sonda-lambda-audi-...542969829.html
    Czy lepiej kupić jakąś droższą?
    Łatwo jest to samemu wymienić? Czy trochę roboty jest z tym?
    Ostatnio edytowane przez w0jt4k ; 07-04-2011 o 20:39
    Kolego moja rada jest taka, nie kombinuj z zamiennikami i kup sonde pod kod twojego motoru, najlepiej nową i bedzie po problemie
    Sonde masz przed katalizatorem wymiana jest prosta ale kanał potrzebny
    sondom przepływkom made in X mówimy nie więc na tej kombinacji tyle zaoszczędzisz że potem i tak kupisz oryginał:P
    Dec 2010
    Czarna
    87
    Yhy, ile taka sonda mniej więcej mnie może wynieść?
    Jutro podzwonie po serwisach różnych.
    Zalezy gdzie kupisz może i 900 może i 400
    Dec 2010
    Czarna
    87
    A te sondy na allegro się nie nadadzą?
    Ceny z Bosch takich sond to od 200 do 350 zł.
    06A 906 262 - numer części z ETKA. Boscha będzie ok pod warunkiem, że nie będzie podróba.
    Edit: dla pewności @WOWO to jest ta przed katalizatorem, nie?
    Ostatnio edytowane przez Jaqob ; 07-04-2011 o 22:15
    ja chyba 200z jakims groszem dałem za sondę bosch szerokopasmową
    Powodem wystąpienia błędu 17524 może być
    -przepalony bezpiecznik
    -przerwa na przewodach elektrycznych lub brak połączenia elektrycznego na wtyczce .
    -uszkodzona sonda lambda .
    Sprawdź dwa pierwsze punkty i jak nic nie znajdziesz to wymień sondę .
    Jeśli chodzi o dylematy z sonda to był na forum nie dawno omawiany temat , wpisałem w szukajkę '' sonda lambda '' i wyszło na pierwszej pozycji
    http://www.klubtt.pl/ogallne/7389-so...a-wymiana.html
  1. Pomocy ! Pierwszy skan i tyle błędów co robić :/
    Ostatni post / autor: 04-12-2015, 10:12
  2. Pierwszy skan - pomoc z analizą błędów
    Odpowiedzi: 19
    Ostatni post / autor: 27-01-2015, 16:51
  3. PawelM skan błędów - tylko 1 :)
    Przez PawelM w dziale MK1 (1998-2006)
    Ostatni post / autor: 30-01-2012, 10:51
  4. pierwszy skan błędów
    Przez ziembol89 w dziale VAG-COM
    Ostatni post / autor: 27-01-2012, 13:15
  5. Audi TT 180KM vs Mercedes W211 E270 180KM
    Przez Chmoora w dziale Kill on street
    Ostatni post / autor: 04-02-2009, 21:38
