raczej temperatura bezpośrednie z silnika go grzeje. Lepiej go nie owiać taśma![]()
jeżeli chcesz go "chodzić" trochę lepiej kup coś takiego.
Made from a high performance polymer Power Gasket™ conducts on average less than 1/500th of the heat of the steel gasket that it replaces. Your intake manifold will stay 30-50° F cooler and your incoming air will stay 20-30° F cooler.Power Gasket™ has been designed for affordability easy installation and no disruption to your manifold attachment and engine accessories. This means that you can simply swap your old intake manifold gasket for a Power Gasket. No buying longer bolts or installing multiple gaskets. In less than 2 hours you will be enjoying a more powerful better performing ride.
[ Dodano: Nie Wrz 02, 2007 10:15 pm ]
