scan silnika:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 8N0 906 018 AB
Component and/or Version: 1.8L R4/5VT 0002
Software Coding: 05500
Work Shop Code: WSC 06435
8 Faults Found:
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
16621 - Manifold Pressure / Boost Sensor (G31): Signal too Low
P0237 - 35-00 - -
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
P0106 - 35-00 - -
17746 - Camshaft Position Sensor (G40) Open or Short to Plus
P1338 - 35-00 - -
18041 - Accelerator Position Sensor 2 (G185): Signal too Low
P1633 - 35-00 - -
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
P1639 - 35-10 - - - Intermittent
po wykasowaniu na wylaczonym silniku zostaje:
1 Fault Found:
P0237 - 35-00 - -
[ Dodano: |15 Lip 2010|, 2010 18:50 ]
to jest auto-scan:
Chassis Type: 8N - Audi TT
Controller: 8N0 906 018 AB
Component: 1.8L R4/5VT 0002
Coding: 05500
Shop #: WSC 06435
1 Fault Found:
P0237 - 35-00 - -
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8N0 907 379 D
Component: ESP 20 CAN V006
Coding: 23049
Shop #: WSC 06435
No fault code found.
Controller: 8N0 820 043
Component: TT-KLIMAVOLLAUTOMAT D01
Coding: 00040
Shop #: WSC 06435
1 Fault Found:
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to B+ - Intermittent
Skipping Address 15-Airbags
Controller: 8N1 919 860 C
Component: KOMBI+WEGFAHRS. M73 D24
Coding: 00044
Shop #: WSC 74802
Ident.-Nr. Wegfahrs.:AUZ5Z0X6192050
Controller: 8N8 962 267
Component: Zentralverrieg. D01
Coding: 04672
Shop #: WSC 01236
3 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01559 - Drivers Door
61-00 - Won't De-Safe
01617 - Please Check DTC Memory of Interior Monitoring
35-00 - -
Address 56 -------------------------------------------------------
Controller: 4B0 035 186 E
Component: Radio 0001
Coding: 00201
Shop #: WSC 00000
2 Faults Found:
00852 - Loudspeaker(s): Front
36-00 - Open Circuit
01044 - Control Module Incorrectly Coded
35-00 - -
End -------------------------------------------------------
[ Dodano: |15 Lip 2010|, 2010 19:11 ]
po wykasowaniu bledow:
Coding: 05500
Shop #: WSC 06435
1 Fault Found:
P0237 - 35-00 - -
Coding: 23049
Shop #: WSC 06435
Coding: 00040
Shop #: WSC 06435
Coding: 00044
Shop #: WSC 74802
Coding: 04672
Shop #: WSC 01236
Coding: 00201
Shop #: WSC 00000
2 Faults Found:
35-00 - -
ide zrobic logi dynamiczne
