brak mocy logi do oceny
witam. posiadam TT 8n 1.8T 180km AJQ i od jakiegos czasu brakuje mi mocy. wykonałem logi w grupie 003 i 011. mógłby ktoś ocenić ? ( PS. robiłem logi pierwszy raz, wiec jakby było cos źle zrobione to sorki). Pierwsze na LPG, drugie PB :
1:
Friday,10,August,2018,18:00:08
8N0 906 018 A ,,1.8l R4/5VT 0008,
,Group A:,'003,,,,Group B:,'011,,,,Group C:, Not Running
,,RPM,Mass Flow,Load,Ign. Timing,,RPM,Temperature,Temperature,Ign. Timing,,,,,
,TIME,,,,,TIME,,,,,TIME,,,,
MARKER,STAMP, /min, g/s,%, °BTDC,STAMP, /min,°C,°C, °BTDC,STAMP,,,,
,0.30,1560,20.39,80.0,10.5,0.00,1520,90.0,43.0,18. 8,,,,,
,0.90,1600,22.11,100.0,16.5,0.60,1560,90.0,42.0,16 .5,,,,,
,1.50,1720,26.14,100.0,17.3,1.20,1680,90.0,40.0,17 .3,,,,,
,2.10,1840,29.94,100.0,16.5,1.80,1760,90.0,39.0,15 .8,,,,,
,2.70,1960,33.69,100.0,14.3,2.40,1920,90.0,39.0,15 .8,,,,,
,3.30,2120,39.47,100.0,12.8,3.00,2040,90.0,38.0,13 .5,,,,,
,3.90,2280,47.19,99.6,11.3,3.60,2200,90.0,37.0,12. 0,,,,,
,4.50,2440,53.06,100.0,11.3,4.20,2360,90.0,37.0,11 .3,,,,,
,5.09,2600,56.78,100.0,9.0,4.79,2520,90.0,37.0,11. 3,,,,,
,5.70,2800,60.53,100.0,13.5,5.40,2720,90.0,37.0,12 .8,,,,,
,6.29,2960,61.64,100.0,17.3,5.99,2880,90.0,37.0,15 .8,,,,,
,6.89,3120,64.94,100.0,17.3,6.60,3040,90.0,37.0,18 .0,,,,,
,7.49,3360,69.89,100.0,20.3,7.20,3240,90.0,37.0,17 .3,,,,,
,8.09,3520,72.08,82.7,20.3,7.79,3440,90.0,38.0,19. 5,,,,,
,8.70,3680,72.31,85.9,21.0,8.39,3600,90.0,39.0,21. 0,,,,,
,9.30,3840,74.44,86.7,21.8,8.99,3760,90.0,39.0,20. 3,,,,,
,9.90,4000,75.44,72.9,22.5,9.60,3920,90.0,39.0,20. 3,,,,,
,10.50,4160,77.75,54.1,23.3,10.19,4080,90.0,39.0,2 3.3,,,,,
,11.10,4320,79.86,49.4,23.3,10.80,4240,90.0,40.0,2 2.5,,,,,
,11.70,4440,80.17,44.7,23.3,11.39,4360,90.0,41.0,1 9.5,,,,,
2.
Friday,10,August,2018,18:04:49
,0.00,1520,26.28,25.5,11.3,0.30,1560,90.0,48.0,9.0 ,,,,,
,0.60,1600,23.14,100.0,9.0,0.90,1640,90.0,48.0,15. 8,,,,,
,1.20,1720,25.75,100.0,12.0,1.50,1760,90.0,47.0,12 .8,,,,,
,1.80,1800,30.33,100.0,9.0,2.10,1880,90.0,46.0,9.8 ,,,,,
,2.40,1920,34.47,100.0,5.3,2.70,2000,90.0,45.0,3.8 ,,,,,
,3.00,2080,42.47,100.0,7.5,3.30,2160,90.0,45.0,5.3 ,,,,,
,3.60,2200,48.14,100.0,3.8,3.90,2320,90.0,45.0,0.8 ,,,,,
,4.20,2360,57.53,100.0,0.8,4.50,2480,90.0,45.0,2.3 ,,,,,
,4.80,2560,61.19,100.0,3.8,5.10,2640,90.0,46.0,3.0 ,,,,,
,5.40,2720,65.50,100.0,3.8,5.70,2840,90.0,46.0,2.3 ,,,,,
,5.99,2920,72.78,100.0,5.3,6.30,3000,90.0,46.0,5.3 ,,,,,
,6.60,3080,74.94,100.0,6.0,6.89,3200,90.0,47.0,4.5 ,,,,,
,7.19,3280,77.47,100.0,7.5,7.50,3360,90.0,48.0,6.0 ,,,,,
,7.80,3440,80.61,100.0,7.5,8.09,3560,90.0,48.0,9.0 ,,,,,
,8.39,3640,84.86,100.0,9.0,8.69,3720,90.0,49.0,6.8 ,,,,,
,8.99,3800,87.61,100.0,6.0,9.29,3880,90.0,50.0,6.8 ,,,,,
,9.60,3960,84.64,100.0,5.3,9.89,4040,90.0,50.0,9.0 ,,,,,
,10.19,4120,79.14,63.9,9.8,10.50,4160,90.0,51.0,11 .3,,,,,
,10.79,4240,81.33,69.4,11.3,11.09,4320,90.0,51.0,1 2.0,,,,,
,11.40,4360,80.69,48.2,12.0,11.70,4440,90.0,52.0,1 2.8,,,,,
,12.00,4520,81.83,44.7,14.3,12.30,4600,90.0,52.0,1 3.5,,,,,
,74.36,840,2.14,1.6,7.5,74.06,840,91.0,49.0,9.0,,, ,,
,74.96,840,2.31,2.0,8.3,74.66,840,90.0,49.0,9.8,,, ,,
Podstawa to sprawdź szczelność układu.
Zrób takie logi
002, 020, 031
115, 118
Następnie ściągnij sobie program CSVConv i przekonwertuj (te logi) do Excel. Zrób Print Screen i wrzuć na forum, a będą wyglądać tak:
https://www.klubtt.pl/showthread.php...-oceny-MKI-APX
Pozdrawiam.
Ostatnio edytowane przez gigo ; 10-08-2018 o 22:43
Witaj,
Wg mnie:
- logi robimy na 3-biegu do odcięcia do 6500-6700, a nie do 4500 (trzeba jeszcze raz zrobić logi)
- za mało pokazuje przepływomierz, chociaż wartość rosła (ale test skończył się na 4500)
- turbina ładnie pompuje.
Nie wiem jak zaworek N75, ale niech wypowiedzą się bardziej doświadczone osoby.
Pozdrawiam.
Ostatnio edytowane przez gigo ; 16-09-2018 o 13:29
Pierwszy raz brałem się za logi, ale czytałem że do 4.5k, jeśli będzie trzeba to zrobię jeszcze raz do odcięcia
zrób jeszcze raz do odcinki
Przepływka na pewno za mało wskazuje, więc albo nieszczelnosc albo przepływomierz.
Wysłane z mojego C1-U02 przy użyciu Tapatalka
