Witam, wlasnie przeskanowalem moja tt vagiem i wyskoczylo mi to:
VAG-COM Version: Release 311.2-N
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Controller: 8N0 906 018 F
Component: 1.8L R4 5VT 0003
Coding: 05610
Shop #: WSC 01236
1 Fault Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8N0 907 379 A
Component: ABS/EDS 20 IE CAN V001
Coding: 13504
Shop #: WSC 01236
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8N0 820 043
Component: TT-KLIMAVOLLAUTOMAT D02
Coding: 00040
Shop #: WSC 01236
2 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to B+
00792 - A/C Pressure Switch (F129)
31-00 - Open or Short to Ground
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8N1 919 860 C
Component: KOMBI+WEGFAHRS. M73 D27
Coding: 00144
Shop #: WSC 00478
Ident.-Nr. Wegfahrs.:AUZ5Z0Y3212205
Address 22 -------------------------------------------------------
Controller: 02D 900 554 B
Component: HALDEX LSC ECC 0006
Address 35 -------------------------------------------------------
Controller: 8N8 962 267
moglby ktos kto sie na tym zna objasnic czy cos jest nietak i jak tak to co mozebyc przyczyna, dodam ze samochod nielata jak powinien
