Pokaż wyniki od 1 do 12 z 12
Wątek: MAXVIBE VAG BLAD na życzenie chłopaków z forum
    Oct 2007
    Sosnowiec
    210
    572
    Moje błędy
    VAG-COM Version: Release 311.2-N
    Chassis Type: 8N - Audi TT
    Controller: 8L0 906 018 Q
    Component: 1.8L R4/5VT 0001
    Coding: 11500
    Shop #: WSC 01236
    TRUZZZ8NZ11040855 AUZ5Z0A3113019
    1 Fault Found:
    16804 - Catalyst System: Bank 1: Efficiency Below Threshold
    P0420 - 35-00 - -
    Readiness: 0000 0000
    Address 03 -------------------------------------------------------
    Controller: 8N0 907 379 D
    Component: ESP 20 CAN V006
    Coding: 23049
    Shop #: WSC 01236
    2 Faults Found:
    01423 - Lateral Acceleration Sensor (G200)
    57-10 - Electric Circuit Failure - Intermittent
    27-10 - Implausible Signal - Intermittent
    Controller: 8N0 820 043 A
    Component: TT-KLIMAVOLLAUTOMAT D03
    Coding: 00040
    Shop #: WSC 01236
    6 Faults Found:
    00787 - Temperature Sensor in Fresh Air intake duct (G89)
    30-10 - Open or Short to B+ - Intermittent
    00779 - Outside Air Temp Sensor (G17)
    30-00 - Open or Short to B+
    01274 - Air Flow Flap Positioning Motor (V71)
    41-10 - Blocked or No Voltage - Intermittent
    01273 - Fresh Air Blower (V2)
    17-10 - Control Difference - Intermittent
    01206 - Signal for Duration of Ignition: OFF
    01582 - Signal for Coolant Temperature
    Skipping Address 15-Airbags
    Controller: 8N1 920 880 H
    Component: KOMBI+WEGFAHRS. M73 D53
    Coding: 00044
    Shop #: WSC 71323
    No fault code found.
    Controller: 8N8 962 267
    Component: Zentralverrieg. D05
    Coding: 06720
    Shop #: WSC 01236
    1 Fault Found:
    00957 - Key 3
    09-10 - Adaptation Limit Surpassed - Intermittent
    End -------------------------------------------------------
    Aug 2007
    z daleka
    945
    01423 - Lateral Acceleration Sensor (G200): No or Incorrect Basic Setting / Adaptation
    Possible Symptoms
    Malfunction Indicator Light (MIL) active
    Possible Causes
    Lateral Acceleration Sensor (G200) Basic Setting lost/not performed
    Possible Solutions
    Perform Lateral Acceleration Sensor (G200) Basic Setting
    See Vehicle specific Diagnostic Procedures for Details
    01423 - Lateral Acceleration Sensor (G200): Electric Circuit Failure
    Possible Symptoms
    Possible Causes
    Wiring/Connections from/to Lateral Acceleration Sensor (G200) faulty
    Supply Voltage insufficient
    Possible Solutions
    Check Wiring/Connections from/to Lateral Acceleration Sensor (G200)
    Check Supply Voltage
    Check Lateral Acceleration Sensor (G200) faulty
    0779 - Outside Air Temperature Sensor (G17): Open or Short to Plus
    Possible Symptoms
    In the Instrument Cluster you see dashes (---) instead of a temperature
    Possible Causes
    Wiring between Outside Air Temperature Sensor (G17) and Instrument Cluster: Open or Short Circuit
    Possible Solutions
    Check wiring between Outside Air Temperature Sensor (G17) and Instrument Cluster
    Check Measuring Block Value
    00779 - Outside Air Temperature Sensor (G17): Short to Ground
    01274 - Air Flow Flap Positioning Motor (V71): Faulty
    Possible Causes
    Wiring/Connectors from/to Air Flow Flap Positioning Motor (V71) faulty
    Positioning Air Flow Flap Positioning Motor (V71) blocked
    Positioning Air Flow Flap Positioning Motor (V71) faulty
    Possible Solutions
    Check Air Flow Flap Positioning Motor (V71)
    See Measuring Value Blocks (MVB)
    Perform Output Test
    Perform Basic Setting
    Check/Repair Wiring and Connectors
    Possible Causes
    Fresh Air Blower (V2) defective
    Control Module for Fresh Air Blower (J126) defective
    Wiring defective
    Possible Solutions
    Check Fresh Air Blower (V2)
    Perform Output Test (Check Air Vents while Blower is active)
    Check Meas. Blocks while Blower is active
    Check Control Module for Fresh Air Blower (J126)
    Check wiring
    Possible Causes
    Ignition Switch faulty
    Wiring between Instrument Cluster (J285) and Climatronic Control (J255) faulty
    Instrument Cluster (J285) faulty
    Possible Solutions
    Check Ignition Switch
    Check Wiring between Instrument Cluster (J285) and Climatronic Control (J255)
    Check Instrument Cluster (J285)
    Check Climatronic Control (J255)
    00957 - Key 3: Adaptation Limit Surpassed
    Possible Symptoms
    Remote control not working.
    Possible Causes
    Key not matched.
    Key operated more than 200 times while out of range.
    Possible Solutions
    See vehicle specific page for synchronisation/adaptation procedures
    paru blędów jak widzisz nie udalo mi się znaleźć ale to może Arttur da radę i tu wlaśnie Maxvibe, nastepnym razem prosze Cie o pasanie na ten temat w innym temacie - jest tam coś o blędach i VAG-cimie bo ten temat juz malo przypomina trmat o weżach i do Arttura moze dasie to wszystko przenieść bo sie syf zrobil
    NO RISK,
    NO FUN.
    Marki
    850
    max podrzuć link z tymi błędami... skąd to dokładnie bierzesz ?
    Czarne jest piękne
    Oct 2007
    Sosnowiec
    210
    572
    co skąd biore z vaga swojego ! Oki bo sie offtopic zrobił
    Jun 2008
    Polska
    260
    257
    panowie ja w kwestii formalnej, po co wklejacie zawartość całego skanu, który zajmuje sporo miejsca skoro nie we wszystkich grupach występują błędy, może lepiej to jakoś usystematyzować i zacząć wklejać tylko istotne informacje o błędach, jak np w przypadku wstawki Maxvibe z błędami adamkatowice :
    16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
    P0130 - 35-10 - - - Intermittent
    01366 - Opened Due to Crash Signal
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01616 - Signal Wire to Interior Monitor
    36-10 - Open Circuit - Intermittent
    00955 - Key 1
    00957 - Key 3
    moim zdaniem adamkatowice powinieneś na początek je wykasować i zobaczyć czy powracają, może są to jakieś nagromadzone stare błędy i nie warto się nimi przejmować
    Edit by Arttur
    Post Adama zostal usuniety z tego watku a odpowiedz na jego problem jest w temacie jego autorstwa
    Awatar Arttur
    8,861
    Maxvibe 16804 - Catalyst System: Bank 1: Efficiency Below Threshold - Twoj odwieczny blad zniknie po zainstalowaniu dystansu miedzy 2-ga sonda lambda a reszta wydechu , pisalem Ci o tym chyba z 4 razy
    Bledy z adresu 03 dotycza czujnika przyspieszenia poprzecznego G200 , musisz sprawdzic polaczenie elektryczne tego sensora jak i sam sensor , jednak zanim co kolwiek zaczniesz robic , wykasyj blad i sprawsz czy pojawi sie ponownie ..
    Tak samo bledy z adresu 8 czyli klima i wentylacja kabiny , wszystkie sa sporadyczne (Intermittent ) , wykasuj i sprawdz czy pojawia sie ponownie ..
    Twoje bledy nie maja wplywu na osiagi , pisales ze auto nie chodzi tak jak powinno wiec obstawiam na nieszczelnosc w ukladzie lub Twoj NO NAME program ..
    Aug 2007
    z daleka
    945
    xylo, magia, magia-na wyspie zwanej internet wszystko jest mozliwe
    NO RISK,
    NO FUN.
    Marki
    850
    Cytat Zamieszczone przez max1236454
    heh rozumiem, że dzięki temu nadal czujesz się potrzebny )
    Czarne jest piękne
    10,795
    Podpisuje się pod tym recyma i nogima
    Aug 2007
    z daleka
    945
    xylo, poczekamy jak Ty bedziesz szukal POMOCY
    NO RISK,
    NO FUN.
    Awatar Arttur
    8,861
    No i znowu OT ..
    Link do tej strony byl juz na forum , oto on :
    http://wiki.ross-tech.com/index.php/...ry:Fault_Codes
    Maxvibe Pokaz jakiemus fachowcowi te foty i niech Ci dorobi cos w tym stylu ...
    lub..
    albo ..
    ewentualnie ..
    Gwint pod sonde lambda jest M18x1,5 ..
    Oct 2007
    Sosnowiec
    210
    572
    Dzięki mam nadzieje ze zrobią tak jak jest napisane bez kręcenia nosem ;-D Może faktycznie auto przez cheek engine ( na leże do tego %) i nie może sie ustawic na dłuższa mete.
    [ Dodano: 21 Grudzień 2008, 18:30 ]
    Panowie u mnia strasznie długa ta adaptacja ale są już rezultaty w postaci mielenia opon i ASP ehheh tylko czasmi czuje ze mi czegoś ubywa w postaci ciśniania ale spoko załatwiłem na czwartek garaż z kanałem wiec wszystko dobrze posprawdzam.Wesołych ¦wiąt ;-D
    [ Dodano: 27 Grudzień 2008, 14:53 ]
    Robiłem dzisiaj test doładowania blok 115 i wyszło np. przy max obrotów różnica miedzy pierwszym a drugim wyszło zdecydowanie większa w ostatnim polu
    990 a drugi 1100 i mniejwięcej zawsze spora różnica
    Przedstawie szczegółowo jak sie pogoda porawi bo ślisko jest bardzo ;-D
  1. blad vag
    Przez iceice w dziale MK1 (1998-2006)
    Odpowiedzi: 1
    Ostatni post / autor: 17-07-2016, 22:50
  2. Co to za bląd ?
    Przez Szakus w dziale MK1 (1998-2006)
    Ostatni post / autor: 17-05-2016, 18:52
  3. Prośba do chłopaków jeżdzących na MBC
    Przez Kasprzyk19 w dziale Ogólne
    Odpowiedzi: 16
    Ostatni post / autor: 20-02-2012, 00:03
  4. co to za blad???
    Przez charli22122 w dziale VAG-COM
    Odpowiedzi: 5
    Ostatni post / autor: 26-07-2010, 07:16
  5. Spalanie na życzenie ;)
    Przez BarTTek w dziale Ogólne
    Odpowiedzi: 5
    Ostatni post / autor: 28-08-2009, 08:12
