Dopiero dzisiaj udało mi się przeskanować, bo miałem problem z programem
Kod:
VAG-COM Version: Release 409.1-S
Chassis Type: 8N - Audi TT
Address 01: Engine
Controller: 8N0 906 018 S
Component: 1.8L R4/5VT G 0007
Coding: 06600
Shop #: WSC 25166
7 Faults Found:
17526 - Oxygen (Lambda) Sensor Heating: B1 S2: Open Circuit
P1118 - 35-10 - - - Intermittent
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 35-00 - -
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-00 - -
16839 - EVAP System: Large Leak Detected
P0455 - 35-00 - -
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-00 - -
17535 - Fuel Trim: Bank 1 (Mult): System too Rich
P1127 - 35-10 - - - Intermittent
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 35-00 - -
Readiness: 0010 0001
Address 03: ABS Brakes
Controller: 8N0 907 379 C
Component: ABS/EDS 20 IE CAN V003
Coding: 13504
Shop #: WSC 01236
No fault code found.
Address 08: Auto HVAC
Controller: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00140
Shop #: WSC 01236
2 Faults Found:
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
29-10 - Short to Ground - Intermittent
01582 - Signal for Coolant Temperature
27-10 - Implausible Signal - Intermittent
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 8N1 920 930 E
Component: KOMBI+WEGFAHRS. M73 D03
Coding: 03144
Shop #: WSC 00000
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to B+
Address 22: AWD
Controller: 02D 900 554 C
Component: HALDEX LSC ECC 0009
1 Fault Found:
00526 - Brake Light Switch-F
Address 35: Centr. Locks
Controller: 8N
Component: Zentralverrieg. D04
Coding: 00000
Shop #: WSC 00000
4 Faults Found:
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
00956 - Key 2
09-00 - Adaptation Limit Surpassed
01559 - Drivers Door
61-00 - Won't De-Safe
01560 - Passenger Door
Address 45: Inter. Monitor
Controller: 8N8 951 177 A
Component: Innenraumueberw. D09
Coding: 00001
Shop #: WSC 00000
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00010
Shop #: WSC 01236
1 Fault Found:
00776 - Level Control System Sensor: Left Front (G78)
31-00 - Open or Short to Ground
End --------------------------------------------------------------------------------------------------
