Witam.
Mam problem z temperatura. Na Fisie wyskakuje błąd odnośnie " temp płynu chłodniczego".
Podłączyłem kabel i jest różnica między temperaturą wskazywaną na zegarze a podaną w komp. Gdy na liczniku pokazuje ( za grzałem sinik ) 100 stopni to w vag pokazuje 84 stopnie. Zrobiłem scan vagiem:
VAG-COM Version: Release 409.1-S
Chassis Type: 8N - Audi TT
Address 01: Engine
Controller: 8N0 906 018 AQ
Component: 1.8L R4/5VT 0002
Coding: 11500
Shop #: WSC 01236
TRUZZZ8N721027913 AUZ5Z0B2285163
2 Faults Found:
17704 - Error in Mapped Cooling System (usually temp Sensor or Thermostat)
P1296 - 35-00 - -
17947 - Clutch Pedal Switch (F36): Implausible Signal
P1539 - 35-00 - -
Readiness: 0000 1000
Address 03: ABS Brakes
Controller: 8N0 907 379 G
Component: ESP FRONT MK60 0101
Coding: 0019469
Shop #: WSC 01236
No fault code found.
Address 08: Auto HVAC
Controller: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00040
Shop #: WSC 04611
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 8N1 920 900
Component: KOMBI+WEGFAHRS. M73 D03
Coding: 00144
Shop #: WSC 03480
1 Fault Found:
00668 - Supply Voltage Terminal 30
53-10 - Supply Voltage Too Low - Intermittent
Address 35: Centr. Locks
Controller: 8N8 962 267
Component: Zentralverrieg. D06
Coding: 06752
Shop #: WSC 04610
10 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
07-10 - Signal too Low - Intermittent
00991 - Interior Lights
28-10 - Short to B+ - Intermittent
01616 - Signal Wire to Interior Monitor
36-00 - Open Circuit
01568 - Signal for Convenience Opening
28-00 - Short to B+
01569 - Signal for Convenience Closing
28-00 - Short to B+
29-00 - Short to Ground
28-00 - Short to B+
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
00956 - Key 2
End --------------------------------------------------------------------------------------------------
Control Module Part Number: 8N0 906 018 AQ
Component and/or Version: 1.8L R4/5VT 0002
Software Coding: 11500
Work Shop Code: WSC 01236
Additional Info: TRUZZZ8N721027913 AUZ5Z0B2285163
2 Faults Found:
P1296 - 35-00 - -
P1539 - 35-00 - -
Wyświetla się też błąd czek engine taka żółta kontrolka silnika oraz airbag ale to od poduszko kierowcy z tego co wiem. Poduszka jest lecz prawdopodobnie taśma do wymiany:
Control Module Part Number: 8N0 959 655 A
Component and/or Version: Airbag Front+Seite 5000
Software Coding: 01102
2 Faults Found:
00588 - Airbag Igniter: Driver Side (N95)
33-10 - Resistance too Low - Intermittent
00532 - Supply Voltage B+
Wydaje mi się że może być czujnik temp do wymiany. Jeżeli tak to jak wymienić i prosił bym o interpretacje tych wszystkich błędów.
Dzięki koledzy![]()
