Witam :/ Słuchajcie zrobiłem auto skan i nie wiem co robić mam tyle błędów że nie wiem co mam myśleć :/ Jeśli możecie to proszę o pomoc co robić i jak je usunąć. Z góry dzięki !
VAG-COM Version: Release 311.2-N
Chassis Type: 8N - Audi TT
Controller: 8N0 906 018 A
Component: 1.8L R4 5VT G 0010
Coding: 05500
Shop #: WSC 00468
2 Faults Found:
17524 - Oxygen (Lambda) Sensor Heating: B1 S1: Open Circuit
P1116 - 35-00 - -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-00 - -
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8N0 907 379
Component: ASR 20 IE CAN 0001
Coding: 13204
Shop #: WSC 01236
No fault code found.
Controller: 8N0 820 043
Component: TT-KLIMAVOLLAUTOMAT D02
Coding: 00040
Shop #: WSC 01236
Skipping Address 15-Airbags
Controller: 8N1 919 860 C
Component: KOMBI+WEGFAHRS. M73 D23
Coding: 00144
Shop #: WSC 131071
Ident.-Nr. Wegfahrs.:AUZ5Z0X2222123
3 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-10 - Open or Short to B+ - Intermittent
01128 - Immobilizer Pickup Coil (D2)
35-10 - - - Intermittent
01176 - Key
07-10 - Signal to Low - Intermittent
Controller: 8N8 962 267
Component: Zentralverrieg.,DWA D04
Coding: 04682
Shop #: WSC 01236
4 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01616 - Signal Wire to Interior Monitor
36-10 - Open Circuit - Intermittent
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
Address 45 -------------------------------------------------------
Controller: 8N8 951 177
Component: Innenraumueberw. D08
Coding: 00001
Shop #: WSC 00000
End -------------------------------------------------------
