Monday,04,August,2014,15:14:03:14533
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: License Plate: BARTEK
Mileage: 182420km-113350mi Repair Order:
Chassis Type: 8N - Audi TT (1999 > 2007)
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Mileage: 182420km/113350miles
Address 01: Engine Labels: 06A-906-032-APX.clb
Part No: 8N0 906 018 F
Component: 1.8L R4 5VT 0003
Coding: 05610
Shop #: WSC 12599
VCID: 346D20B50403AABE4FF-5140
2 Faults Found:
17830 - Secondary Air Injection Solenoid Valve (N112)
P1422 - 35-00 - Short to Plus
17947 - Clutch Pedal Switch (F36)
P1539 - 35-00 - Implausible Signal
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8N0-907-379-MK20.lbl
Part No: 8N0 907 379 A
Component: ABS/EDS 20 IE CAN V001
Coding: 13504
Shop #: WSC 01236
VCID: 3A710E8D26675CCE953-4AEA
No fault code found.
Address 08: Auto HVAC Labels: 8N0-820-043.lbl
Part No: 8N0 820 043
Component: TT-KLIMAVOLLAUTOMAT D02
Coding: 00041
Shop #: WSC 01236
VCID: E7D707F985559126BAD-2582
Address 15: Airbags Labels: 8N8-909-601.lbl
Part No: 8N8 909 601
Component: Airbag Front+Seite 1005
Coding: 10102
Shop #: WSC 01236
VCID: F7F757B9D5F501A62AD-5122
Address 17: Instruments Labels: 8Nx-920-xxx-17.lbl
Part No: 8N2 920 930
Component: KOMBI+WEGFAHRS. M73 D24
Coding: 04444
Shop #: WSC 131071
VCID: EFE76FD9ADA54966F2D-4AEA
Subsystem 1 - Part No: Ident
Component: Nr. Wegfahrs.:AUZ5Z0X9253297
Ident.-Nr. Wegfahrs.:AUZ5Z0X9253297
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
VCID: 1F47DF199D8519E682D-4AEA
Address 35: Centr. Locks Labels: 8Nx-962-267.lbl
Part No: 8N8 962 267 B
Component: Central Lock/Alarm D04
Coding: 04810
Shop #: WSC 01236
VCID: 40857C6540BB061EDB7-4ECE
4 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01616 - Signal Wire to Interior Monitor
36-10 - Open Circuit - Intermittent
01134 - Alarm Horn (H12)
49-00 - No Communications
01617 - Please Check DTC Memory of Interior Monitoring
35-10 - - - Intermittent
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8N8 951 177
Component: Innenraumueberw. D09
Coding: 00001
Shop #: WSC 00000
VCID: FCFD4895ECD322FE47F-51B6
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
35-00 - -
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00010
Shop #: WSC 01236
VCID: E5CB0DF17F598336881-51B6
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 186 D
Component: Radio 0001
Coding: 00517
Shop #: WSC 01236
VCID: 2143D9E1ABF12F16B49-4B04
1 Fault Found:
00852 - Loudspeaker(s); Front
36-00 - Open Circuit
