VAG-COM Version: Release 311.2-N
Chassis Type: 8N - Audi TT
Controller: 8N0 906 018 S
Component: 1.8L R4/5VT G 0004
Coding: 06600
Shop #: WSC 00000
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8N0 907 379 C
Component: ABS/EDS 20 IE CAN V003
Coding: 13504
Shop #: WSC 01236
Controller:
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Controller: 8N1 920 930 C
Component: KOMBI+WEGFAHRS. M73 D24
Coding: 06144
Shop #: WSC 131071
Address 22 -------------------------------------------------------
Controller: 02D 900 554 B
Component: HALDEX LSC ECC 0006
1 Fault Found:
00526 - Brake Light Switch-F
27-10 - Implausible Signal - Intermittent
Controller: 8N8 962 267 A
Component: Central Lock/Alarm D04
Coding: 15884
Shop #: WSC 01236
Address 45 -------------------------------------------------------
Controller: 8N8 951 177 A
Component: Innenraumueberw. D09
Coding: 00001
Shop #: WSC 00000
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00010
Shop #: WSC 01236
End -------------------------------------------------------
