Bez "wiedzy tajemnej" mozesz zdekodowac tyle ile tutaj:
http://s2central.net/vin_entry_sonic.html
[ Dodano: Czw Maj 22, 2008 11:43 am ]
No coz... za dobrze to nie wyglada..Zamieszczone przez payne100
VIN : TRUZZZ8NZY1017902
Kod modelu: 8N3069
Silnik: APX № 7269
Moc = 165 KW ( 225 KM)
Kolor : 5B 5B JN
Rynek : Niemcy
Produkcja: 13.08.1999
Rok modelowy : 2000
Wyposazenie:
0A1 = 2 doors
0AN = Stabilizer, front
0BJ = Rear stabilizer
0CV = Vehicle class differentiation 8N0
0F2 = Fuel system for carburetor gasoline engine
0FA = Standard manufacturing sequence
0G4 = Cable gearshift
0GF = Emissions concept D3 EU3D
0L2 = Electric throttle actuation
0LW = Special plates/stickers/ safety certificates for Germany
0N5 = Standard rear axle
0RA = Without ignition/starter switch locking system
0ST = Labels/plates in German and French
0VC = Information kit in German
0W1 = Label for central electric German-speaking countries
0YP = Weight range 14 installation control only, no requirement forecast
1AH = Electronic differential lock (EDL)
1C1 = Antifreeze up to -25 degree celsius tolerance up to -30 degree C
1D0 = Without trailer hitch
1E1 = Activated carbon canister
1EX = Special identification plate for EC
1G0 = Without spare wheel
1GS = Front shock absorption (AUDI TT)
1H0 = Without proportioning valve
1JL = Rear shock absorption
1KF = Disc brakes, rear
1LT = Disc brakes, front
1N4 = Power steering
1PC = Wheel bolts with anti-theft protection (unlockable)
1SA = Without additional engine guard
1T3 = First aid kit with warning triangle
1X1 = Four wheel drive
1Z2 = Increase in initial standard fuel filling
2A4 = Delivery equipment for shipment (transitcoating) with thick seat cover
2B9 = Additional exterior noise suppression
2C5 = Axial and vertical adjustable steering column
2D1 = Complete cd enhancing underbody panel
2G9 = Filler neck module 2 with insert
2K1 = Reinforced bumpers
2LB = Fuel tank with special material treatment
2V1 = Dust and pollen filter
2W0 = Fuel filler cap
2WA = Without additional tires
2Z1 = Type sign at rear and "Quattro" nameplates respectively
2ZN = Leather trimmed sports steering wheel with aluminum appearance
3B0 = Without additional child seat anchor
3FA = Without roof insert (standard roof)
3H5 = Backrest release for front seats with additional backrest release on the innerside
3L3 = Manual height adjustment for front seats
4A3 = Seat heater for front seats separately controlled
4E6 = Tailgate/trunk lid release from inside only
4GH = Windshield in heat-insulating glass with sunshield
4K4 = Radio remote controlled central locking
4M0 = Without cup holder
4P0 = Rear floor panel module, type 1
4R1 = Power windows
4SD = Left vanity mirror, illuminated
4TD = Right vanity mirror illuminated
4UF = Drivers and front passenger air bag with front passenger air bag deactivation
4X1 = Side air bag front
5C7 = Additional body measures
5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
5F0 = Without hardtop
5K5 = Transit coating film with additional transport protection measures
5RU = Right exterior mirror: convex (large viewing field)
5SL = Left exterior mirror: aspherical
6E0 = Without center armrest front
6N0 = Without mud flaps
6PA = Plastic hand brake lever handle
6Q7 = Leather gearshift knob with aluminum appearance
6R3 = Rubber gearshift boot
6V1 = Rear trim panel (ECE)
6W5 = Front license plate bracket
6XD = Exterior mirrors: electrically adjustable/heated
7A2 = CD changer
7CA = Without label for radio remote control
7E0 = W/o heat accumulator/auxiliary heating
7L0 = Without inertia benefit system/ deceleration fuel cut-off/idle stop valve
7P0 = Without lumbar support in seat backrests
7Q0 = Without navigation device
7QA = Without CD/DVD for navigation
7S0 = Without wind blocker
7X0 = Without park distance control
8CC = Speedometer sensor without seal (electronic speedometer sensor)
8GL = Alternator 120 A
8JG = Headlight with gas discharge lamp for driving on the right
8K0 = Without special low beam mode
8M0 = W/o rear window wiper and washer system
8N4 = Windshield wiper intermittent control with potentiometer (four speeds)
8Q2 = Automatic headlight-range adjustment static
8RY = Speakers with BOSE sound
8T0 = Without cruise control system (CCS)
8TC = Rear fog light for driving on the right
8UD = Radio "concert"
8W1 = Washer fluid level indicator
8X1 = Headlight washer system
8Y1 = Two-tone horn
8Z5 = Not hot country
9AK = Climatronic with impact pressure control free of cfc
9D0 = Without preparation for two-way radio installation
9JD = Smoking package, ashtray front
9M0 = Without auxiliary/parking heater
9P0 = Without seat belt warning light
9Q2 = Multi-function display/on-board computerwith check control
9T1 = Heated washer nozzles, front
9U0 = Without brake pad wear indicator
9V7 = Electronic vehicle immobilization devicewith anti-theft alarm system and passenger compartment control
9W0 = W/o car phone preparation/installation
9Y1 = Outdoor temperature gage
A00 = No self-collection
A8S = Standard equipment
B0A = Component parts set without country-specific design requirement
B99 = Type approval EC
C03 = Operating permit, alteration
C4N = Alloy wheels 7.5J x 17
E0A = No special edition
F0A = No special purpose vehicle, standard equipment
FA0 = Control of standard production
FC0 = Without customized installation
G0L = 6-speed manual transmission for four-wheel drive vehicle
H6G = Tires 225/45 ZR17 91Y
J1L = Battery 280 A (60 Ah)
K8C = Coupe
L0L = Left-hand drive vehicle
M4S = 4-cyl. turbo gasol. eng. 1.8 L/165kW 20VEU 3D base engine is T6B
N5D = Valcona leather seat covering
PI1 driver information system (DIS)
PLT Leatherette package
PX1 xenon headlights
Q1D = Sports front seats
QG0 = Without service interval prolongation
QV0 = W/o TV reception/digital radio reception
RCM = Radio system "gamma" with digital sound package (DSP) and removable operating panel
SA9 = Inventory control model 4
T6B = 4-cylinder gasoline engine 1.8 L unit 06A.G
U1A = Instrument insert with km/h speedometer,clock, tachometer and trip odometer
U93 = Suspension range 192
V0A = Tires w/o specification of tire brand
VC0 = W/o remote-controlled garage door opener
