Jestem nowy na forum.. (Sledze je z uwaga od jakiegoś czasu)
Mam pytanko, zamierzam kupić audi TT i mam prośbę odnośnie rozszyfrowania nr VIN!! Pomoże ktoś?
NR VIN:TRUZZZ8NZY1023615
Z góry dziękuje i POZDRAWIAM![]()
VIN: TRUZZZ8NZY1023615
Digit(s) Parameter Code(s) Meaning
1-2 Country TR Hungary
3 Manufacturer U Audi
4-6 Blanks ZZZ ---
7-8 Vehicle Type 8N VW Platform, Audi TT including quattro and Roadster variants (1998 - 2006)
9 Check/Blank Z -
10 Model Year Y 2000
11 Factory 1 Built in Gyor, Hungary
12-17 Chassis Number 023615 Serial Number 023615
dokladniejszego dekodera aktualnie nie ma ale sprobuje cos zalatwic..
ttless..
Zamieszczone przez kilazz
Dzięki śliczne, jakbyś znalazł coś dokładniejszego to będę wdzięczny
Jest to auto z 1999r, quattro 225ps, xenon, bose, z kierownica po lewej, dokladniej zdekodowane nizej..
VIN : TRUZZZ8NZY1023615
Code of the car: 8N3069
The engine : APX № 10540
Capacity(Power) = 165 KW (225 лс.)
Codes of colors : 5B 5B JN
Code of a check point : DQB
Code of the country : X0A (X0A = National sales program Germany
Date prod.: 27.09.1999
Modelling year: 2000
0A1 = 2 doors
0AN = Stabilizer, front
0BJ = Rear stabilizer
0CV = Vehicle class differentiation 8N0
0F2 = Fuel system for carburetor gasoline engine
0FA = Standard manufacturing sequence
0G4 = Cable gearshift
0GF = Emissions concept D3 EU3D
0L2 = Electric throttle actuation
0LW = Special plates/stickers/ safety certificates for Germany
0N5 = Standard rear axle
0RA = Without ignition/starter switch locking system
0ST = Labels/plates in German and French
0VC = Information kit in German
0W1 = Label for central electric German-speaking countries
0YP = Weight range 14 installation control only, no requirement forecast
1C1 = Antifreeze up to -25 degree celsius tolerance up to -30 degree C
1D0 = Without trailer hitch
1E1 = Activated carbon canister
1EX = Special identification plate for EC
1G0 = Without spare wheel
1GS = Front shock absorption (AUDI TT)
1H0 = Without proportioning valve
1JL = Rear shock absorption
1KF = Disc brakes, rear
1LT = Disc brakes, front
1N4 = Power steering
1PC = Wheel bolts with anti-theft protection (unlockable)
1SA = Without additional engine guard
1T3 = First aid kit with warning triangle
1X1 = Four wheel drive
1Z2 = Increase in initial standard fuel filling
2A4 = Delivery equipment for shipment (transitcoating) with thick seat cover
2B9 = Additional exterior noise suppression
2C5 = Axial and vertical adjustable steering column
2D1 = Complete cd enhancing underbody panel
2G9 = Filler neck module 2 with insert
2K1 = Reinforced bumpers
2LB = Fuel tank with special material treatment
2V1 = Dust and pollen filter
2W0 = Fuel filler cap
2WA = Without additional tires
2Z1 = Type sign at rear and "Quattro" nameplates respectively
2ZN = Leather trimmed sports steering wheel with aluminum appearance
3B0 = Without additional child seat anchor
3FA = Without roof insert (standard roof)
3H5 = Backrest release for front seats with additional backrest release on the innerside
3L3 = Manual height adjustment for front seats
4A3 = Seat heater for front seats separately controlled
4E6 = Tailgate/trunk lid release from inside only
4GH = Windshield in heat-insulating glass with sunshield
4K4 = Radio remote controlled central locking
4M0 = Without cup holder
4P0 = Rear floor panel module, type 1
4R1 = Power windows
4SD = Left vanity mirror, illuminated
4TD = Right vanity mirror illuminated
4UF = Drivers and front passenger air bag with front passenger air bag deactivation
4X1 = Side air bag front
5C7 = Additional body measures
5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
5F0 = Without hardtop
5K5 = Transit coating film with additional transport protection measures
5RU = Right exterior mirror: convex (large viewing field)
5SL = Left exterior mirror: aspherical
6E0 = Without center armrest front
6N0 = Without mud flaps
6PA = Plastic hand brake lever handle
6Q7 = Leather gearshift knob with aluminum appearance
6R3 = Rubber gearshift boot
6V1 = Rear trim panel (ECE)
6W5 = Front license plate bracket
6XD = Exterior mirrors: electrically adjustable/heated
7A2 = CD changer
7CA = Without label for radio remote control
7E0 = W/o heat accumulator/auxiliary heating
7L0 = Without inertia benefit system/ deceleration fuel cut-off/idle stop valve
7P0 = Without lumbar support in seat backrests
7Q0 = Without navigation device
7QA = Without CD/DVD for navigation
7S0 = Without wind blocker
7X0 = Without park distance control
8CC = Speedometer sensor without seal (electronic speedometer sensor)
8GL = Alternator 120 A
8JG = Headlight with gas discharge lamp for driving on the right
8K0 = Without special low beam mode
8M0 = W/o rear window wiper and washer system
8N4 = Windshield wiper intermittent control with potentiometer (four speeds)
8Q2 = Automatic headlight-range adjustment static
8RY = Speakers with BOSE sound
8T0 = Without cruise control system (CCS)
8TC = Rear fog light for driving on the right
8UD = Radio "concert"
8W1 = Washer fluid level indicator
8X1 = Headlight washer system
8Y1 = Two-tone horn
8Z5 = Not hot country
9AK = Climatronic with impact pressure control free of cfc
9D0 = Without preparation for two-way radio installation
9JD = Smoking package, ashtray front
9M0 = Without auxiliary/parking heater
9P0 = Without seat belt warning light
9Q2 = Multi-function display/on-board computerwith check control
9T1 = Heated washer nozzles, front
9U0 = Without brake pad wear indicator
9V7 = Electronic vehicle immobilization devicewith anti-theft alarm system and passenger compartment control
9W0 = W/o car phone preparation/installation
9Y1 = Outdoor temperature gage
A00 = No self-collection
A8S = Standard equipment
B0A = Component parts set without country-specific design requirement
B99 = Type approval EC
C04 = Operating permit, alteration
C4N = Alloy wheels 7.5J x 17
E0A = No special edition
F0A = No special purpose vehicle, standard equipment
FA0 = Control of standard production
FC0 = Without customized installation
G0L = 6-speed manual transmission for four-wheel drive vehicle
H6G = Tires 225/45 ZR17 91Y
J1L = Battery 280 A (60 Ah)
K8C = Coupe
L0L = Left-hand drive vehicle
M4S = 4-cyl. turbo gasol. eng. 1.8 L/165kW 20VEU 3D base engine is T6B
N7U = Alcantara/pearl napa leather seat cover.
PI1 = Driver Information System
PX1 = Xenon Headlights
Q1D = Sports front seats
QG0 = Without service interval prolongation
QV0 = W/o TV reception/digital radio reception
RCM = Radio system "gamma" with digital sound package (DSP) and removable operating panel
SA9 = Inventory control model 4
T6B = 4-cylinder gasoline engine 1.8 L unit 06A.G
U1A = Instrument insert with km/h speedometer,clock, tachometer and trip odometer
U93 = Suspension range 192
V0A = Tires w/o specification of tire brand
VC0 = W/o remote-controlled garage door opener
ttless..
Pewnie dostales wiecej takich maili jak ten...![]()
Serdecznie proszę Cię o zdekodowanie mojego VINa. Mam troche niejasnosci co do mojej TTki.
TRUZZZ8NZY1017902
Dzieki z góry!
Pozdrowienia,
Marcin
Skoro juz jestes szczesliwym posiadaczem, to moze nie wyjasniaj, zeby sie nie stresowacZamieszczone przez payne100
Sam bylem kiedys swiadkiem, jak gosc sprawdzal nowo nabytego Forda w autoryzowanym i pan mu powiedzial, ze jego auto bylo wczoraj w UK na przegladzie i ma kierownice po prawej stronie. Gosc zmienil kolorek ...
A tak serio. Mozecie posadzic na portal link do sprawdzenia VIN'a jezeli to nie jest wiedza tajemna lub prawem chroniona?
Pozdro Artix
Bez "wiedzy tajemnej" mozesz zdekodowac tyle ile tutaj:
http://s2central.net/vin_entry_sonic.html
[ Dodano: Czw Maj 22, 2008 11:43 am ]
No coz... za dobrze to nie wyglada..Zamieszczone przez payne100
VIN : TRUZZZ8NZY1017902
Kod modelu: 8N3069
Silnik: APX № 7269
Moc = 165 KW ( 225 KM)
Kolor : 5B 5B JN
Rynek : Niemcy
Produkcja: 13.08.1999
Rok modelowy : 2000
Wyposazenie:
0A1 = 2 doors
1AH = Electronic differential lock (EDL)
4R1 = Power windows
7A2 = CD changer
8Y1 = Two-tone horn
C03 = Operating permit, alteration
K8C = Coupe
N5D = Valcona leather seat covering
PI1 driver information system (DIS)
PLT Leatherette package
PX1 xenon headlights
ttless..
Czy ktos moglby dla mnie rozkodowac ten : TRUZZZ8NZ11015827 ? Z tego ogolnego malo sie mozna dowiedziec![]()
