,a, mastepujace bledy o czego zaczas? pozdrawiam adam
Kody AdamaKatowice.Pozdro
VAG-COM Version: Release 311.2-N
Chassis Type: 8N - Audi TT
Controller: 8N0 906 018 A
Component: 1.8L R4 5VT 0010
Coding: 05500
Shop #: WSC 01236
1 Fault Found:
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8N0 907 379
Component: ASR 20 IE CAN 0001
Coding: 13204
Shop #: WSC 01236
No fault code found.
Controller: 8N0 820 043
Component: TT-KLIMAVOLL
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Controller: 8N1 919 880 E
Component: KOMBI+WEGFAHRS. M73 D24
Coding: 04044
Shop #: WSC 131071
Ident.-Nr. Wegfahrs.:AUZ5Z0X8243315
Controller: 8N7 962 267
Component: Zentralverrieg.,DWA D04
Coding: 04698
Shop #: WSC 01236
5 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01616 - Signal Wire to Interior Monitor
36-10 - Open Circuit - Intermittent
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
00957 - Key 3
Address 45 -------------------------------------------------------
Controller: 8N7 951 177
Component: Innenraumueberw. D13
Coding: 00001
Shop #: WSC 77976
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00009
Shop #: WSC 01236
Address 56 -------------------------------------------------------
Controller: 4B0 035 186
Component: Radio 0001
Coding: 00017
Shop #: WSC 06335
End -------------------------------------------------------
W zasadzie masz jeden istotny blad dotyczacy pierwszej sondy lambda , mysle ze bez wymiany sondy die nie obejdzie ..
16514/P0130/000304 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
Bledy z adresu 35 to centralny zamek i alarm , mysle ze po wykasowaniu nie beda powracac , moze za wyjatkiem jednego ale nie maja one wplywu na osiagi i zachowanie sie auta![]()
