Witam. Koledzy - szukam auta i stoję przed dylematem. Zlogowałem dwie TTki, którymi jestem zainteresowany. Prosze o pomoc w analizie:
Srebrna TT
logi
błędy
VAG-COM Version: Release 409.1-US
Control Module Part Number: 8N0 906 018 A
Component and/or Version: 1.8L R4 5VT 0010
Software Coding: 05500
Work Shop Code: WSC 01236
3 Faults Found:
17931 - Crash Signal from Airbag Controller: Implausible Signal
P1523 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
18084 - EPC Warning Lamp (K132) Circuit: Electrical Malfunction
P1676 - 35-10 - - - Intermittent
Control Module Part Number: 8N8 909 601
Component and/or Version: Airbag Front+Seite 0005
Software Coding: 10102
6 Faults Found:
00588 - Airbag Igniter: Driver Side (N95)
32-00 - Resistance too High
00589 - Airbag Igniter 1: Passenger Side (N131)
00654 - Seat Belt Tensioner Igniter: Driver Side (N153)
00655 - Seat Belt Tensioner Igniter: Passenger Side (N154)
01217 - Side Airbag Igniter: Driver Side (N199)
65535 - Internal Control Module Memory Error
00-00 - -
Czarna TT
logi
błędy
Chassis Type: 8N - Audi TT
Address 01: Engine
Controller: 8N0 906 018 AB
Component: 1.8L R4/5VT 0002
Coding: 05500
Shop #: WSC 06435
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8N0 907 379 D
Component: ESP 20 CAN V006
Coding: 23049
Shop #: WSC 06435
1 Fault Found:
00287 - ABS Wheel Speed Sensor: Rear Right (G44)
35-00 - -
Address 08: Auto HVAC
Controller: 8N0 820 043
Note: Excessive Comm Errors
Wychodzi na to, ze srebrna miala dzwona i ma duzo gorsze odczyty z logów. Prosze o pomoc.
