Pokaż wyniki od 1 do 9 z 9
Wątek: Airbag??
    Awatar Piootr
    Oct 2007
    280
    692
    Airbag??
    Witam
    Na zlocie dzieki Michałowi zrobilismy mały scan samochodu, i wyskoczyły mi takie błędy, a głownie interesuje mnie jeden, ten grubymi literami. I zaznaczam że poduszki nigdy nie były otwarte. Ale AIRBAG mi sie cały czas swieci.
    Chassis Type: 8N - Audi TT
    Controller: 8N0 906 018 AE
    Component: 1.8L R4/5VT 0001
    Coding: 05710
    Shop #: WSC 06435
    1 Fault Found:
    16955 - Brake Switch (F): Implausible Signal
    P0571 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Controller: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18446
    Shop #: WSC 06435
    No fault code found.
    Controller: 8N0 820 043
    Component: TT-KLIMAVOLLAUTOMAT D02
    Coding: 00040
    Shop #: WSC 06435
    1 Fault Found:
    00792 - A/C Pressure Switch (F129)
    31-00 - Open or Short to Ground
    Skipping Address 15-Airbags
    Controller: 8N1 920 880 A
    Component: KOMBI+WEGFAHRS. M73 D23
    Coding: 04044
    Shop #: WSC 43753
    Ident.-Nr. Wegfahrs.:AUZ5Z0X5042209
    Address 22 -------------------------------------------------------
    Controller: 02D 900 554 B
    Component: HALDEX LSC ECC 0006
    1 Fault Found:
    00526 - Brake Light Switch-F
    Controller: 8N8 962 267
    Component: Zentralverrieg.,DWA D04
    Coding: 04682
    Shop #: WSC 01236
    7 Faults Found:
    35-00 - -
    01572 - Alarm triggered by Door Contact Switch: Passenger Side
    35-00 - -
    35-00 - -
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    36-10 - Open Circuit - Intermittent
    00849 - S-contact at Ignition/Starter Switch (D)
    Address 45 -------------------------------------------------------
    Controller: 8N8 951 177
    Component: Innenraumueberw. D09
    Coding: 00001
    Shop #: WSC 00000
    1 Fault Found:
    01463 - Alarm triggered by Sensor for anti-theft alarm System
    35-00 - -
    Address 55 -------------------------------------------------------
    Controller: 4B0 907 357
    Component: LEUCHTWEITEREGLER D003
    Coding: 00010
    Shop #: WSC 06435
    End -------------------------------------------------------
    Control Module Part Number: 8N8 909 601
    Component and/or Version: Airbag Front+Seite 0005
    Software Coding: 10102
    Work Shop Code: WSC 06435
    1 Fault Found:
    65535 - Internal Control Module Memory Error
    00-10 - - - Intermittent
    Nov 2008
    OLSZTYN
    20
    Re: Airbag??
    Cytat Zamieszczone przez Piootr
    Witam
    Coding: 05710
    Shop #: WSC 06435
    1 Fault Found:
    Coding: 18446
    Shop #: WSC 06435
    Coding: 00040
    Shop #: WSC 06435
    1 Fault Found:
    Coding: 04044
    Shop #: WSC 43753
    1 Fault Found:
    Coding: 04682
    Shop #: WSC 01236
    7 Faults Found:
    35-00 - -
    35-00 - -
    35-00 - -
    35-00 - -
    35-00 - -
    Coding: 00001
    Shop #: WSC 00000
    1 Fault Found:
    35-00 - -
    Coding: 00010
    Shop #: WSC 06435
    1 Fault Found:
    hej nie pamietam czy ci mówiłem na zlocie że to może być czujnik w przegrodzie,zmiany biegów gadałem z gosciem w olsztynie i powiedział mi że po zimie często pada jakiś czujnik pod wpływem wilgoci i że wymieniał go w 2 tt i bylo to właśnie przyczyna.zajedż do jakiegos elektryka i niech ci sprawdzi ten czujnik.
    pozdrawiam.
    Apr 2003
    France Avignon
    380
    Srebny
    466
    Re: Airbag??
    Cytat Zamieszczone przez KARLOS
    Witam
    pozdrawiam.
    +1 czujnik albo pod siedzeniem jest kostkę. Tylko pamiętaj wyłączenie akumulatora jak się bawić z tym :P
    911 Kiler
    May 2009
    Szczecin/Hamburg
    161
    niestety i mnie dopadła przygoda z kontrolką AIRBAG. zapaliła sie podczas jazdy. na względnie prostej i równej drodze... Po ponownym uruchomieniu silnika nadal nie gaśnie..
    zastanawia mnie przyczyna? przy tym samochodzie chyba VAG to obowiązkowe wyposażenie... masakra jakaś! czy tą elektrykę składały jakieś małpy czy jak?
    ma ktoś z Was pomysł od czego zacząć sprawdzanie?
    Skan VAG jako oczywisty przyszedł mi do głowy ale nie mam niestety dostępu ...
    Czy w przypadku winnej kostki po poprawieniu styków kontrolka powinna zgasnąć czy tylko poprzez terminal można ją wyłączyć?
    PZDR!
    Wylączysz ją tylko Vagiem lub odłącz aku na pól godż jężeli to błąd czasowy to powinien zniknąć
    Odnośnie elektryki w to w większości przypadków problem leży po stronie nieudolnych fachowców którzy wkladali w nią swoje łapska np po jakiejś naprawie lub wypadku
    Jul 2009
    Katowice
    142
    często jak ruszasz fotel (przestawiasz go) wypinają się kostki lub się poruszają i się kontrolka zaświeci. najlepiej najpierw zacząć od skanu (wszystko wyjdzie)
    JEST MOC
    May 2009
    Szczecin/Hamburg
    161
    OK jutro zobacze gdzie mogła wypiąć się kostka...prawdopodobnie u pasażera bo dzisiaj ten fotel był przestawiany. mam nadzieję że to ta przyczyna.
    Czy po odłączeniu aku na pół godziny nie będę miał innych atrakcji w stylu kalibracje, odkodowywanie radia? bo taka zabawa to jakby wpaść z deszczu pod rynnę...
    inna sprawa to VAG... kurcze mam kompa z Vista i z tego co wiem ciężko o VAG działający pod tym cudem IT.
    wiecie może czy tem http://allegro.pl/item759114411_zrob...rogram_pl.html działa faktycznie także pod Vistą? sprzedający twierdzi, że do działania programu potrzebna jest między innymi Vista.
    PZDR!
    Jedynie będziesz musiał odkodować radio reszta skalibruje się sama po kilku kilometrach
    Oct 2008
    Koszalin
    85
    miałem podobno sytuację czyściłem auto przesuwałem fotele no i kilka godzin później niespodzianka świeci się kontrolka AIRBAG napociłem się godzinę jaka to przyczyna VAG wywalał już chciałem nawet rozbierać czy w ogóle tam jest poduszka bo auto było ze dwa tygodnie po kupieniu, ale ostatnia myśl przesuwane fotele - odpiąłem kostkę przemyłem specjalnym płynem do styków w spraju podłączyłem załączyłem VAGa skasowałem i do dnia dzisiejszego a to już ponad rok OK
  1. Kontrolka AirBag
    Przez longer w dziale MK1 (1998-2006)
    Odpowiedzi: 24
    Ostatni post / autor: 23-09-2021, 14:14
  2. błąd airbag vag
    Ostatni post / autor: 16-11-2015, 14:45
  3. AirBag i zegary
    Przez Witku w dziale MK1 (1998-2006)
    Ostatni post / autor: 27-02-2015, 14:34
  4. Sensor airbag
    Przez sokoleoko w dziale MK1 (1998-2006)
    Ostatni post / autor: 06-06-2013, 08:59
