Pokaż wyniki od 1 do 15 z 15
Wątek: Ponowny skan Vag-com
    Awatar mLody
    Jan 2009
    Koszalin
    srebro
    176
    Witam po ponownym przeskanowaniu TT pojawiły mi sie następujące błędy:
    Chassis Type: 8N - Audi TT
    Controller: 8N0 906 018 AB
    Component: 1.8L R4/5VT 0002
    Coding: 05500
    Shop #: WSC 76139
    4 Faults Found:
    17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
    P1113 - 35-00 - -
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 35-10 - - - Intermittent
    16622 - Manifold Pressure / Boost Sensor (G31): Signal too High
    P0238 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Controller:
    Component: Zentralverrieg.,DWA D01
    Coding: 32767
    Shop #: WSC 131071
    72 Faults Found:
    01371 - Alarm triggered by Door Contact Switch: Driver's Side
    01572 - Alarm triggered by Door Contact Switch: Passenger Side
    01369 - Alarm triggered by Hood Switch
    01368 - Alarm triggered by Luggage Compartment Switch
    01373 - Alarm triggered by Radio Ground Contact
    01558 - Contact Switch in Locking Cyl: Driver Side: Close (F241)
    01557 - Contact Switch in Locking Cyl: Driver Side: Open (F241)
    00000 - End of Output
    00-10 - - - Intermittent
    01563 - Interior Lock Switch: Driver Side (E150): Lock
    01564 - Interior Lock Switch: Driver Side (E151): Unlock
    00947 - Trunk Lid remote Control Switch (E18
    01565 - Luggage Compartment Light (W3)
    28-10 - Short to B+ - Intermittent
    00668 - Supply Voltage Terminal 30
    07-10 - Signal to Low - Intermittent
    00991 - Interior Lights
    36-10 - Open Circuit - Intermittent
    01568 - Signal for Convenience Opening
    01569 - Signal for Convenience Closing
    01357 - Tank Flap Locking Motor (V155)
    01555 - Motors for Central Locking: Save [Safe?]
    01556 - Motors for Central Locking: Unlock
    00955 - Key 1
    00956 - Key 2
    00957 - Key 3
    00958 - Key 4
    01570 - Turn-Off Delay: Terminal 15
    01559 - Drivers Door
    58-10 - Can't Lock - Intermittent
    01560 - Passenger Door
    59-10 - Can't Unlock - Intermittent
    60-10 - Won't Safe - Intermittent
    61-10 - Won't De-Safe - Intermittent
    01552 - Motor for Central Locking: Drivers Door (V56): Lock
    01553 - Motor for Central Locking: Passenger Door (V57): Lock
    01554 - Motors for Central Locking: Rear Doors: Lock
    00949 - Central Locking Motor - tailgate (V53): LOCK
    00849 - S-contact at Ignition/Starter Switch (D)
    31-10 - Open or Short to Ground - Intermittent
    01581 - Incorrect Component Detected
    01379 - Interior Monitor Switch (E183)
    30-10 - Open or Short to B+ - Intermittent
    01482 - Motors for Central Locking
    01617 - Please Check DTC Memory of Interior Monitoring
    00-00 - -
    Skasowałem błędy sondy, jeżeli pojawią się na nowo to znaczy że sonda definitywnie do wymiany tak?
    Tu przestroga dla tych którzy zastanawiają sie czy kupić Boscha czy zamiennik, bo sondę mam może ze 2 miesiące
    1. co oznacza błąd: 16622 ?
    2. mam mnóstwo błędów związanych z centralnym zamkiem, chociaż dziś udało mi sie go przekodować właśnie tak jak chciałem, czyli potwierdzenie otwarcia-zamknięcia mignięciem kierunków itp.
    Dużo się z tym bawiłem bo nie mogłem sie zalogować do mod. komfortu ale pomógł link od Arttura- wielkie dzięki
    Ale do rzeczy czy tymi błędami mimo że są mam sie nie przejmować?
    3. co oznacza błąd : 01617 - Please Check DTC Memory of Interior Monitoring
    Z góry wielkie dzięki za pomoc- Pozdrawiam!
    Awatar Bart227
    małopolskie
    Silver
    400
    Błąd ten może oznaczać uszkodzony MAP sensor.
    Spróbuj odpiąć wtyczkę z MAP sensora i zobacz czy pojawi się ten błąd.
    W Twoim przypadku (Signal too High) może oznaczać że turbina przeładowuje. U Ciebie w 90% błąd ten jest spowodowany złymi wskazaniami sondy lambda i przepływomierza.
    Wymień te części na oryginały Boscha, wymień BOV-a na DV FORGE 007 i błędy poznikają, a autko zacznie śmigać.
    Co do reszty błędów związanych z centralnym zamkiem to może kto inny pomoże bo nie mam pojęcia
    Aug 2007
    z daleka
    945
    mLody, ja ci się nie dziwei że auto nie ma mocy 4+72=76 błedów kórw@ ja się dziwie ze Ty tym jeździsz i nieboisz się so swoje mLode życie wstaw to auTTo jak najszybciej do mechanika bo rozwalisz do końca i bedziesz szukał albo nowego kompa albo nowy silnik
    [ Dodano: 22 Luty 2009, 14:58 ]
    16622/P0238/000568 - Manifold Pressure/Boost Sensor (G31): Signal too High
    Possible Symptoms
    Malfunction Indicator Lamp (MIL) active
    Possible Causes
    Wiring/Connector(s) from/to Manifold Pressure/Boost Sensor (G31) faulty
    Possible Solutions
    Check Wiring/Connector(s) from/to Manifold Pressure/Boost Sensor (G31)
    Check Manifold Pressure/Boost Sensor (G31)
    NO RISK,
    NO FUN.
    koszalin
    353
    może jak rozcinali auto na pół a potem zespawali drugą połowę z innego auto to ci wszystkie kable poprzecinali i stad te błędy szokens może sam już przy tym aucie nic nie rób bo jeszcze samo się zapali albo inne cuda będą
    a tak poważnie wtaw do warsztatu
    http://owex.firmy.net/
    Awatar mLody
    Jan 2009
    Koszalin
    srebro
    176
    Spoko, ja tam się nie gniewam bo zauważyłem, że kto by nie poprosił o pomoc czy o ocenę swojego auta do doszukujesz się złego malowania, spasowania części i dodajesz "humorystyczne aluzje" Jeżeli jesteś pierwszym właścicielem swojej tetetki od fabryki i jesteś jej pewny że przyjechała na kołach od naszych sąsiadów to pozazdrościć.
    Chciałbym po prostu wiedzieć co oznaczają poszczególne błędy, pojade do serwisu, prosta kalkulacja:
    1500 wizyta z robocizną + 3000 nowy ECU bo fachowcy w ten sposób poradzą sobie z błędami SUMA=4500 zł
    koszalin
    353
    żaden nowy ecu nie pomoże na na błędy centrala!
    wykasuj błędy pojeździj trochę przeskanuj ponownie i dopiero wrzuć na forum cześć powinna zniknąć.
    część błędów centrala jest wynikiem wypadku więc o ile nie ma uszkodzeń mechanicznych powinny nie powrócić
    duża część błędów jest wynikiem twojej zabawy w kodowanie kilka nieudanych adaptacji
    01617 - Please Check DTC Memory of Interior Monitoring co do tego błędu to też raz na ruski rok się u mnie pojawi
    A wiec wykasuj ponowny skan wrzuć na forum to będziemy myśleć
    a i czy po wymianie sondy kasowałeś błędy ?? jeżeli tak to w 100% już pada
    może się zdążyć że wykasujesz i się nie pojawi przez jakiś czas ale pewnie wróci !
    Przepływka może ją czyściłeś i coś poszło nie tak albo nie kasowałeś błędów nie wiem
    zanim ją wymienisz spróbuj wyczyścić tak jak opisane na forum powinno pomóc
    no i nie zapomnij kasować błędów tyle czekam na dalsze błedy
    Nie chcę wychodzić na czepialskiego ale tt to nie golf i na takim aucie nie powinno się oszczędzać na częściach
    Dobra wiadomość jest taka że sondę możesz zareklamować
    16514 i 17521 Nieprawidlowo dzialajaca sonda lambda ..
    16486 - Przeplywka , albo niesprawna albo nieprawidlowo podlaczona , sprawdz przewody , jesli sa ok to zostaje przeplywka ..
    16622 - Tak jak koledzy pisali to MAP sensor , moze po prostu masz odlaczony ..
    W 180 jest on mocowany do Intercoolera . Z tym ze jesli taka sytuacja mialaby miejsce u Ciebie to auto powinno chodzic bardzo kiepsko i nierowno na biegu jalowym ..
    Bledow z centralnego zamka nawet nie chce mi sie interpretowac , tyle tego jest
    Jednak nie wplywaja one na osiagi ani bezpieczenstwo i moga byc wynikiem Twoich eksperymentow .
    Wejdz po prostu w 35 Cent.Locks i wykasuj bledy mysle ze wiekszosc z nich nie pojawi sie ponownie ..
    Awatar mLody
    Jan 2009
    Koszalin
    srebro
    176
    Upewnie się czy ten MAP sensor jest podłączony ale dowiedziałem się że może on ulec awarii gdy mamy niesprawną sondę!
    A co do sondy chcę wyrzucić ten zamiennik co tam siedzi i kupić boscha, tylko ze numer oryginału który był przed podróbką to: 06A 906 262 AG, a dziś w serwisie audi gość powiedział mi, że żadna inna tylko o numerze 06A 906 262 Q, powinna być, zgłupiałem
    Nie chciałbym kupić złej, posiada ktoś dostęp do takich informacji katalogowych jaka powinna siedzieć u mnie?
    Pozdrawiam!
    Noo i jeszcze taką informacje znalazłem :
    http://skoda.wtychach.pl/products.ph...121&kind=22339
    Nie jest to prawda z ta sonda i MAP sensorem ..
    Wejdz w blok pomiarowy 115 i zobacz czy i jakie wskazania sa z MAP sensora
    Jesli chodzi o sonde lambda to nie wiem jaki masz rocznik auta , w pierwszych latach produkcji byly sondy waskopasmowe pozniej szerokopasmowe , jedz do serwisi i niech gosc sprawdzi w Etce z uwzglednieniem rocznika ..
    Chyba ze ktos na forum sprawdzi , moja etka jest na kompie ktory mi teraz nie dziala
    Mlody, jedyny pożytek z auta to modne zdjęcie w avatarze hehehee
    Oddaj do ASO to 'cacko' albo przyszyj sobie na stałe do ręki vaga na bluetoothcie,
    i czekaj na message: "DO NOT START THE ENGINE OR YOU WILL DIE"
    Ps. a teraz tak na spokojnie : JAPIERD!#$ nigdy czegos takiego nie widziałem
    Awatar mLody
    Jan 2009
    Koszalin
    srebro
    176
    Spoko nie ma obawy, te wszystkie błędy c. zamka to jednak wynik moich kombinacji, adaptacji i kodowania kluczyków, dopiero teraz nauczyłem się prawidłowo korzystać z Vaga, pokasowałem wszystkie błędy i jedynie co teraz mi wyskakuje to:
    no i oczywiście ta sonda:
    Błąd przepływomierza zniknął po zdjęciu BOVa, więc mam aktualnie tylko 2 błędy, nie jest tak tragicznie
    I dzięki za komplement, mi też się podoba avatar :P
    Pozdrawiam!
    (___\==oooo==/___)
    koszalin
    353
    co do tego błędu to może ktoś się wypowie gdyż też jestem ciekaw 01617 - Please Check DTC Memory of Interior Monitoring
    mlody ten błąd ci na pewno wróci 01366 - Opened Due to Crash Signal
    Młody to ładnie tam zawalczyłeś z kodowaniem
    Teraz to faktycznie lepiej wygląda :>
    Awatar mLody
    Jan 2009
    Koszalin
    srebro
    176
    Miałem taki problem, że podchodzę pewnego dnia do TT naciskam kluczyk i zero reakcji, gdy juz miałem interface i Vaga udało mi się dojść jedynie do tego że dział kluczyk ale jedynie zamykał i otwierał furę, namieszałem tam niesamowicie.
    Arttur podrzucił mi link i pokumałem jak to należy prawidłowo wykonać.
    Po przekodowaniu zamykam, otwieram drzwi, migają przy tym kierunki, uaktywnia sie alarm, szyby też z kluczyka działają itp. full servis :P
    Sprawdzam codziennie czy pojawią sie znowu ale wyskakuje mi jedynie:
    Nie wiem jak sie tego pozbyć
    Pozdrawiam!
    (___\==oooo==/___)
    Aug 2007
    kraków
    337
    Odpowiedź na SOS mLody
    Oznacza przerwę lub zwarcie na masę sygnałów związanych z kontrolą wnętrza pojazdu.
    Należy : wymienić czujnik -moduł G209 (przy ośw. wnętrza)
    Mam nadzieję, ze pomoże .....
    Pzdr,
  1. Skan i błędy - 180 AJQ
    Przez Libido w dziale MK1 (1998-2006)
    Ostatni post / autor: 29-03-2015, 10:53
  2. Pierwszy skan- tak na szybko
    Przez VanWave w dziale VAG-COM
    Odpowiedzi: 26
    Ostatni post / autor: 11-02-2013, 21:39
  3. pierwszy skan błędów
    Przez ziembol89 w dziale VAG-COM
    Ostatni post / autor: 27-01-2012, 13:15
  4. Pierwszy skan
    Przez ENZO w dziale VAG-COM
    Odpowiedzi: 22
    Ostatni post / autor: 14-09-2009, 02:09
  5. Skan - jak naprawić?
    Przez Chmoora w dziale VAG-COM
    Ostatni post / autor: 27-07-2009, 18:44
