Pokaż wyniki od 1 do 3 z 3
Wątek: błedy vag pomoże ktoś?
    Oct 2008
    wor
    131
    fiolet
    342
    Witam, wlasnie przeskanowalem moja tt vagiem i wyskoczylo mi to:
    Chassis Type: 8N - Audi TT
    Controller: 8N0 906 018 F
    Component: 1.8L R4 5VT 0003
    Coding: 05610
    Shop #: WSC 01236
    1 Fault Found:
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Controller: 8N0 907 379 A
    Component: ABS/EDS 20 IE CAN V001
    Coding: 13504
    Shop #: WSC 01236
    No fault code found.
    Controller: 8N0 820 043
    Component: TT-KLIMAVOLLAUTOMAT D02
    Coding: 00040
    Shop #: WSC 01236
    2 Faults Found:
    00779 - Outside Air Temp Sensor (G17)
    30-00 - Open or Short to B+
    00792 - A/C Pressure Switch (F129)
    31-00 - Open or Short to Ground
    Skipping Address 15-Airbags
    Controller: 8N1 919 860 C
    Component: KOMBI+WEGFAHRS. M73 D27
    Coding: 00144
    Shop #: WSC 00478
    Ident.-Nr. Wegfahrs.:AUZ5Z0Y3212205
    Address 22 -------------------------------------------------------
    Controller: 02D 900 554 B
    Component: HALDEX LSC ECC 0006
    Controller: 8N8 962 267
    moglby ktos kto sie na tym zna objasnic czy cos jest nietak i jak tak to co mozebyc przyczyna, dodam ze samochod nielata jak powinien
    Aug 2007
    z daleka
    945
    8010/P1602/005634 - Power Supply B+ Terminal 30: Voltage too Low
    Possible Causes
    Cables on the Battery were removed
    Battery weak (voltage)
    Generator Disfunction
    Possible Solutions
    Check Battery Cables
    Check/Replace Battery
    Check/Replace Generator
    Special Notes
    If multiple Control Module have Power Supply Faults stored, it's most likely to be one common Problem like the ones shown above. Otherwise when only one or two Control Modules have such Codes stored you better start searching at the individual Power Supply of these Modules. Intermittent-Przerywany wykasuj ten błąd przejedz ze 100 km - moze samochod stał kilkanaście dni
    00779 - Outside Air Temperature Sensor (G17): Open or Short to Plus
    Possible Symptoms
    In the Instrument Cluster you see dashes (---) instead of a temperature
    Possible Causes
    Wiring between Outside Air Temperature Sensor (G17) and Instrument Cluster: Open or Short Circuit
    Possible Solutions
    Check wiring between Outside Air Temperature Sensor (G17) and Instrument Cluster
    Check Measuring Block Value
    00779 - Outside Air Temperature Sensor (G17): Short to Ground
    Possible Symptoms
    Possible Causes
    Outside Air Temperature Sensor (G17) damaged
    Possible Solutions
    Check / Replace Outside Air Temperature Sensor (G17)
    Possible Symptoms
    A/C System not working
    Possible Causes
    A/C System Malfunctions
    Over or insufficiently charged
    Refrigerant System blockage
    Insufficient Air Flow to Condensor and/or Engine Radiator
    Wiring to/from A/C Pressure Switch (F129) faulty
    Possible Solutions
    Check A/C System for Malfunctions
    Check Wiring to/from A/C Pressure Switch (F129)
    Check A/C Pressure Switch (F129)
    NO RISK,
    NO FUN.
  1. Rozkodowanie Vin-u A4 B8. Pomoże ktoś ?
    Przez krisp w dziale Off top - Free
    Ostatni post / autor: 21-11-2014, 21:55
  2. Pomoże ktoś w instalacji vag 311.2 na win 7?
    Odpowiedzi: 91
    Ostatni post / autor: 08-07-2014, 14:31
  3. Odpowiedzi: 8
    Ostatni post / autor: 25-01-2013, 22:18
  4. błędy
    Ostatni post / autor: 17-10-2012, 16:10
  5. błedy
    Przez rafaelo w dziale VAG-COM
    Ostatni post / autor: 23-08-2009, 18:33
