Moje błędy
Chassis Type: 8N - Audi TT
Controller: 8L0 906 018 Q
Component: 1.8L R4/5VT 0001
Coding: 11500
Shop #: WSC 01236
TRUZZZ8NZ11040855 AUZ5Z0A3113019
1 Fault Found:
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
Readiness: 0000 0000
Controller: 8N0 907 379 D
Component: ESP 20 CAN V006
Coding: 23049
Shop #: WSC 01236
2 Faults Found:
01423 - Lateral Acceleration Sensor (G200)
57-10 - Electric Circuit Failure - Intermittent
Controller: 8N0 820 043 A
Coding: 00040
Shop #: WSC 01236
6 Faults Found:
00787 - Temperature Sensor in Fresh Air intake duct (G89)
30-10 - Open or Short to B+ - Intermittent
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to B+
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
01273 - Fresh Air Blower (V2)
17-10 - Control Difference - Intermittent
01206 - Signal for Duration of Ignition: OFF
01582 - Signal for Coolant Temperature
Skipping Address 15-Airbags
Controller: 8N1 920 880 H
Component: KOMBI+WEGFAHRS. M73 D53
Coding: 00044
Shop #: WSC 71323
No fault code found.
Controller: 8N8 962 267
Component: Zentralverrieg. D05
Coding: 06720
Shop #: WSC 01236
1 Fault Found:
00957 - Key 3
End -------------------------------------------------------
