Oto wynik skanu vagiem iceboya:
Kod:
Chassis Type: 8N - Audi TT
Controller: 8N0 906 018 H
Component: 1.8L R4/5VT 0004
Coding: 10710
Shop #: WSC 01236
TRUZZZ8NZ11034372 AUZ5Z0A1092094
4 Faults Found:
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-10 - - - Intermittent
17704 - Error in Mapped Cooling System (usually temp Sensor or Thermostat)
P1296 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Controller: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18446
Shop #: WSC 01236
No fault code found.
Controller: 8N0 820 043 A
Coding: 00040
Shop #: WSC 01236
Skipping Address 15-Airbags
Controller: 8N1 920 880 K
Component: KOMBI+WEGFAHRS. M73 D52
Coding: 05144
Shop #: WSC 00000
Address 22 -------------------------------------------------------
Controller: 02D 900 554 B
Component: HALDEX LSC ECC 0006
1 Fault Found:
00526 - Brake Light Switch-F
Controller: 8N8 962 267
Component: Zentralverrieg.,DWA D04
Coding: 06730
Shop #: WSC 01236
3 Faults Found:
35-00 - -
00668 - Supply Voltage Terminal 30
07-10 - Signal to Low - Intermittent
36-10 - Open Circuit - Intermittent
Address 45 -------------------------------------------------------
Controller: 8N8 951 177
Component: Innenraumueberw. D09
Coding: 00001
Shop #: WSC 00000
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00010
Shop #: WSC 01236
Address 56 -------------------------------------------------------
Controller: 8L0 035 152 A
Component: Radio 0001
Coding: 00017
Shop #: WSC 00000
End -------------------------------------------------------
Any ideas ?
[ Dodano: 2 Grudzień 2008, 19:43 ]
Dzięki artur,
po wymianie TT Coolant Temperature Sensor (dokładna instrukcja tutaj) http://blog.carrel.org/2005_08_01_archive.html
wynik na vagu:
Kod:
Coding: 10710
Shop #: WSC 01236
Coding: 18446
Shop #: WSC 01236
Coding: 00040
Shop #: WSC 01236
Coding: 05144
Shop #: WSC 00000
Coding: 06730
Shop #: WSC 01236
Coding: 00001
Shop #: WSC 00000
Coding: 00010
Shop #: WSC 01236
Coding: 00017
Shop #: WSC 00000
Za chwile jazda na testy, kopa iceboy ma..
