Pokaż wyniki od 1 do 6 z 6
Wątek: Bledy bledy bledy po przeskanowaniu Vag com ...
    Nov 2007
    Sczecin
    Balck
    121
    Witam wlasnie przeskanowalem wagiem moja tt no i otrzymalem takie cos szukalem wkodach bledow ale nic nie zroumialem szczeze powiedziawszy moze Wy mi pomozecie widze ze sa jakies bledy co z tym zrobic ... oto moj wydruk
    VAG-COM Version: Release 311.2-N
    Chassis Type: 8N - Audi TT
    Controller: 8L0 906 018 M
    Component: 1.8L R4/5VT G 0002
    Coding: 05710
    Shop #: WSC 01236
    3 Faults Found:
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - - Intermittent
    16955 - Brake Switch (F): Implausible Signal
    P0571 - 35-10 - - - Intermittent
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 03 -------------------------------------------------------
    Controller: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18446
    Shop #: WSC 01236
    No fault code found.
    Controller: 8N0 820 043 A
    Component: TT-KLIMAVOLLAUTOMAT D03
    Coding: 00040
    Shop #: WSC 01236
    Skipping Address 15-Airbags
    Controller: 8N1 920 880 H
    Component: KOMBI+WEGFAHRS. M73 D56
    Coding: 05044
    Shop #: WSC 61361
    XXXXXXXXXXXXXXXXX AUZ5Z0E9125076
    Address 22 -------------------------------------------------------
    Controller: 02D 900 554 B
    Component: HALDEX LSC ECC 0006
    Controller: 8N8 962 267
    Component: Zentralverrieg.,DWA D04
    Coding: 06730
    Shop #: WSC 01236
    6 Faults Found:
    01366 - Opened Due to Crash Signal
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01616 - Signal Wire to Interior Monitor
    36-10 - Open Circuit - Intermittent
    00955 - Key 1
    09-10 - Adaptation Limit Surpassed - Intermittent
    01617 - Please Check DTC Memory of Interior Monitoring
    Address 37 -------------------------------------------------------
    Controller: 4B0 919 887 B
    Component: Navigation BNO 0001
    Address 45 -------------------------------------------------------
    Controller: 8N8 951 177
    Component: Innenraumueberw. D09
    Coding: 00001
    Shop #: WSC 00000
    1 Fault Found:
    01463 - Alarm triggered by Sensor for anti-theft alarm System
    35-00 - -
    Address 55 -------------------------------------------------------
    Controller: 4B0 907 357
    Component: LEUCHTWEITEREGLER D004
    Coding: 00010
    Shop #: WSC 01236
    End -------------------------------------------------------
    Awatar Arttur
    8,863
    Nie ma tam nic konkretnego poza jakas przerwa w dzialaniu wlacznika swiatel stopu .
    Poza tym bledy informujace o zadzialaniu systemu alarmowego i za slabym sygnale z kluczyka .
    Wykasuj je wchodzac osobno w dane sterowniki i wiekszosc z nich nie powinna sie pojawic .
    Jesli pojawia sie ponownie to wtedy trzeba sie tym zajac
    Nov 2007
    Sczecin
    Balck
    121
    Dziekuje. Jak zwykle ^Arttur ktory wszystko wie ;D
    Awatar Arttur
    8,863
    E tam , nie ma takiego co wie wszystko
    Awatar arthstudio
    May 2008
    Isle of Man
    2008
    grafitowy
    122
    Aha no i jeszcze jeden błąd. No właśnie, błąd a nie błond Ale fakt, Arttur jest kozak i ma taka sama kurtke jak ja
    Jun 2008
    koszalin
    353
    witam mam powracajacy bład 01617 - Please Check DTC Memory of Interior Monitoring
    co z tym można zrobić jest to jedyny błąd po długiej nierównej walce z moją tt i chciał bym go jakoś usunąc ma ktoś jakieś sugestie
    Sprzedam TT 180 KM rok 99 cena 26000 tel 517385046
    http://owex.firmy.net/
  1. VAG bledy
    Przez Sokol1330 w dziale MK1 (1998-2006)
    Odpowiedzi: 6
    Ostatni post / autor: 09-11-2015, 14:20
  2. Co oznaczaja te bledy?
    Przez pioter w dziale VAG-COM
    Odpowiedzi: 10
    Ostatni post / autor: 05-03-2014, 20:11
  3. Dwa bledy
    Przez lelu666 w dziale VAG-COM
    Ostatni post / autor: 05-10-2012, 22:01
  4. co to za bledy/?
    Przez Badboyboxing w dziale VAG-COM
    Odpowiedzi: 11
    Ostatni post / autor: 21-09-2011, 22:49
  5. Demontarz blędy
    Przez ICE w dziale Ogólne
    Odpowiedzi: 0
    Ostatni post / autor: 28-05-2010, 14:44
