Pokaż wyniki od 1 do 6 z 6
Wątek: OGłOSZENIE - TT DO SPRZEDANIA i uwagi
    Kupujesz TT?
    Byłem dziś ze znajomym oglądać TT-kę:
    http://www.otomoto.pl/index.php?sect=show&id=C5433735
    Zabrałem ze sobą VAGA - z ciekawości...
    Wyniki z testu:
    Kod:
    VAG-COM Version: Release  311.2-N
    Chassis Type: 8N - Audi TT
    Address 01     -------------------------------------------------------
       Controller: 8L0 906 018 M
       Component: 1.8L R4/5VT         0002
       Coding: 05710
       Shop #: WSC 01236
    1 Fault Found:
    17978 - Engine Start Blocked by Immobilizer
                P1570 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 03     -------------------------------------------------------
       Controller: 8N0 907 379 E
       Component: ESP     20    CAN  V004
       Coding: 18446
       Shop #: WSC 01236
    No fault code found.
    Address 08     -------------------------------------------------------
       Controller: 8N0 820 043 A
       Coding: 00040
       Shop #: WSC 00754
    Skipping Address 15-Airbags
    Address 17     -------------------------------------------------------
       Controller: 8N1 920 880 C
       Component: KOMBI+WEGFAHRS. M73 D08
       Coding: 05544
       Shop #: WSC 00000
       Ident.-Nr. Wegfahrs.:AUZ5Z0Y5072034
    Address 22     -------------------------------------------------------
       Controller: 02D 900 554 B
       Component: HALDEX LSC  ECC     0006
    Address 35     -------------------------------------------------------
       Controller: 8N8 962 267
       Component: Zentralverrieg.,DWA D04
       Coding: 06730
       Shop #: WSC 01236
    8 Faults Found:
    35-00 - -
                35-00 - -
                35-00 - -
    00668 - Supply Voltage Terminal 30
                07-10 - Signal to Low - Intermittent
                36-10 - Open Circuit - Intermittent
    00955 - Key 1
    01617 - Please Check DTC Memory of Interior Monitoring
    Address 45     -------------------------------------------------------
       Controller: 8N8 951 177
       Component: Innenraumueberw.    D09
       Coding: 00001
       Shop #: WSC 00000
    1 Fault Found:
    01462 - Anti-theft alarm ultra sonic Sensor (G209)
                53-10 - Supply Voltage Too Low - Intermittent
    Address 56     -------------------------------------------------------
       Controller: 4B0 035 186 D
       Component:  Radio              D05
       Coding: 00207
       Shop #: WSC 01236
    2 Faults Found:
    00850 - Control Output Active: Radio Amplifier
    00855 - Connection to CD changer
                49-10 - No Communications - Intermittent
    End   -------------------------------------------------------
    I teraz wrażenia:
    Auto po uruchomieniu po 5 minutach dochodzi do 110*C, nie działa przednia chłodnica, nie działa wewnętrzna czujka alarmu, nie ma plastików osłaniającyhc pod spodem, samochód przy przyspieszaniu ściąga na prawo, na FIS'ie nonstp "SERVICE!", nie działa klimatyzacja (sypie upałem), przebieg 90tyś km - możliwy, po mocnym dzwonie stał pewnie na szrocie.
    ABS 'ledwo' łapie, akumulator siada po dwóch dniach ( widać po vagu ), przednie amory do wymiany, lewa przednia część stabilizatorów/łączników/wahaczy po wymianie, gumy w stanie zerowym - dodam jeszcze że auto odpala raz na 4 próby.
    Wytne co ciekawsze:
    17978/P1570 - Engine Start Blocked by Immobilizer Adaptation Limit Surpassed Possible Causes
    Key(s) not matched
    Instrument Cluster not matched
    Engine Control Unit (ECU) not matched
    Engine Control Unit (ECU) Power Supply faulty
    Possible Causes
    Output Test performed on Airbag Control Module (J234)
    Vehicle involved in Accident
    Airbag Control Module (J234) stored Crash Data
    Wiring/Connectors from/to Airbag Control Module (J234) faulty
    00955 - Key 1: Adaptation Limit Surpassed
    Possible Causes
    Key not matched.
    00850 - Control Output Active: Radio Amplifier: Short to Ground
    Possible Causes
    Amplifier Control Output Wiring faulty
    I tak na koniec - przypomniałem sobie, rzecz jasna klapa przednia się nie schodzi idealnie z reflektorami... no cóż, to chyba tyle.
    Podziękowałem Panu i odradziłem koledze zakup.
    Szukającym wrażen z TT - ten samochód także odradzam.
    No widzisz , dla tego z zasady nie udzielam sie w tematach typu '' co sadzicie o tej TT ''
    Po zdjeciach nie ma sie do czego za bardzo przyczepic , a tu taka kicha
    Jul 2007
    Gorny Slask
    255
    456
    Malo to takich rodzynkow na allegro.. dobrze ze airbagow nie przetestowales bo pewnie jeszcze wiecej bledow by pokazalo
    ttless..
    Jan 2008
    57
    Może zauważyliście, że to jest BI-TURBO
    No biturbo, bo już miało pewnie dwie turbiny bhehehehe
    BI-GÓWNO a jaki opis nic tylko brać pieprzeni oszuści
  1. >>>>>>>UWAGI<<<<<<<
    Przez boost.pl w dziale Błędy, skargi, komunikaty
    Odpowiedzi: 484
    Ostatni post / autor: 09-09-2020, 05:25
  2. MK2 [8J] Silnik 2.0 TFSI 200KM - opinie i uwagi
    Przez PinBack w dziale Porady przy kupnie Audi TT
    Ostatni post / autor: 07-03-2014, 20:48
