Pokaż wyniki od 1 do 15 z 327
Wątek: G9 KPR R30T MRS Grey.
Widok wątkowy
  1. #11
    Awatar streetrace
    Jun 2015
    Radom
    272
    2008
    Phantom
    548
    Takie coś znalazłem:
    Instruments module 17
    Light/rain sensor
    This is a sub-module of body control and you can adjust the sensitivity for auto-lights and the rain sensitivity for the auto wipers – I found the wipers weren’t sensitive enough
    Byte 0,
    Bit 0 to auto turn lights on above 90mph (not sure if this only work with auto lights)
    Bits 3 and 4 select a more sensitive auto light on threshold – ie lights can come on when it less dark
    Byte 2 rain sensor correction – default setting for tt, but I swapped to 23, 35% a8 (4h) which seemed to give a better range of sweep speeds than the tt one.
    W vcds wchodzisz w 17 - instruments... potem - long coding helper i
    Masz poziomo kwadraty z Byte'mi, a w każdym z nich masz liste bit'ów. VCDS powinien Ci pomóc i podpowiedzieć jak kodować
    Oprócz tego masz jeszcze takie ustawienia:
    Wchodzisz w 09 central electrics
    Byte 18 drl settings
    Default for uk ttrs is 58, which is front leds only , rear lights off. Vcds has various settings in a pulldown box, but if you want the rear lights to be on as well as the leds for drl ( I have this setting) then you manually type in 59 in the byte table, or use 01011001 in the binary field.
    Byte 24 drl brightness
    Bits 0-6, you put in the decimal % brightness 1 to 100
    Bit 7 must be enabled or the drl leds will not light up (? Why this exists I don’t know)
    Firstly this DOES WORK in terms of changing the brightness – other posters have said this doesn’t work but it certainly does on my car
    Secondly I can see big steps in the brightness every 10%, but cant see any change between the default 92% and 99% or 100% - seems to max out about the 92% default
    Thirdly, even low settings like 20% work properly and don’t throw any error codes or dis messages, contrary to some posts I have read.
    Byte 26 but 3 drl only acive with adl disabled will set the drl on when the light switch is off, and they dim when you set the lights to sidelights or headlamps on enabled sets the drl to be on only with the auto lights switch set to auto – when the switch is off, all lights including drl will be off, on auto the drl will be on bright, and on side or main lights the drl leds will be dimmed
    Czujnik na lusterku? Wydaje mi sie ze w ttmk2 mialem czujnik na podszybiu od swiatel dzienne/mijania.
    Obadajcie sobie chłopaki część 8J0857511G to jest lusterko wewnetrzne do 8j z kamerą do high beam assist
    Czujnik zmierzchowy jest na podszybiu, ale nie czujnik anty oślepieniowy pojazdów z przeciwka do HBA
    Ostatnio edytowane przez streetrace ; 17-12-2016 o 23:05
    Audi TTS.
    The Everyday Sportscar.
  1. Nazywam się GREY. TTS METEOR GREY.
    Przez elmacho w dziale MK2 (2006-2014)
    Odpowiedzi: 132
    Ostatni post / autor: 29-09-2018, 21:31
  2. Aviator Grey
    Przez Madd w dziale MK1 (1998-2006)
    Odpowiedzi: 52
    Ostatni post / autor: 08-12-2017, 15:30
  3. Aviator Grey 225PS Quattro - Legion
    Przez Legion w dziale MK1 (1998-2006)
    Odpowiedzi: 8
    Ostatni post / autor: 02-05-2013, 12:40
  4. PICIU - TT 225 Arrow Grey
    Przez Piciu w dziale MK1 (1998-2006)
    Odpowiedzi: 16
    Ostatni post / autor: 09-10-2011, 00:02
