VAG-COM Version: Release 409.1-S
Control Module Part Number: 8N0 906 018 AB
Component and/or Version: 1.8L R4/5VT 0002
Software Coding: 05500
Work Shop Code: WSC 06435
3 Faults Found:
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Address 03: ABS Brakes
Controller: 8N0 907 379 D
Component: ESP 20 CAN V006
Coding: 23049
Shop #: WSC 06435
1 Fault Found:
00812 - Brake Pressure Release Solenoid (F84)
Address 08: Auto HVAC
Controller: 8N0 820 043
Component: TT-KLIMAVOLLAUTOMAT D02
Coding: 00040
Shop #: WSC 06435
No fault code found.
Address 17: Instruments
Controller: 8N1 919 860 C
Component: KOMBI+WEGFAHRS. M73 D26
Coding: 00044
Shop #: WSC 06201
Ident.-Nr. Wegfahrs.:AUZ5Z0Y2142120
Address 35: Centr. Locks
Controller: 8N8 962 267
Component: Zentralverrieg. D03
Coding: 04672
Shop #: WSC 01236
1 Fault Found:
01482 - Motors for Central Locking
29-10 - Short to Ground - Intermittent
Control Module Part Number: 8N8 909 601
Component and/or Version: Airbag Front+Seite 0004
Software Coding: 10102
4 Faults Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
01217 - Side Airbag Igniter: Driver Side (N199)
28-10 - Short to B+ - Intermittent
32-10 - Resistance too High - Intermittent
01218 - Side Airbag Igniter: Passenger Side (N200)
End --------------------------------------------------------------------------------------------------
