Pokaż wyniki od 1 do 2 z 2
Wątek: Bardzo prosze przyjaciele o rozkodowanie VIN, wyposazenia.
    Jul 2014
    Bielsko
    2
    Witam przyjcialee dacie rady rozkodowac mi VIN?
    TRUZZZ8NZX1019106
    Nov 2011
    Elbląg
    310
    516
    Nr nadwozia TRUZZZ8NZX1019106
    model audi tt coupe 1,8
    ATT
    Data produkcji 23.02.1999
    Rok modelowy 1999
    typ handlowy 8N3054
    numer silnika AJQ
    numer skrzyni biegów DZF
    numer napedu osiowego 5S
    Wyposazenie JN
    kolor dachu A2
    kolor zewnetrzny / numer koloru A2 / Y9B
    Activated carbon canister 1E1 Activated carbon canister
    Additional child seat anchors 3B0 Without additional child seat anchor
    Additional tires (winter tires) 2WA Without additional tires
    Air bag 4UF Driver's and front passenger air bag
    with front passenger air bag
    deactivation
    Anti-theft protection system 9V7 Electronic vehicle immobilization device
    with anti-theft alarm system and
    passenger compartment control
    Antifreeze 1C1 Antifreeze up to -25 degree celsius
    tolerance up to -30 degree C
    Auxiliary heating 9M0 Without auxiliary/parking heater
    Backrest release 3H5 Backrest release for front seats with
    additional backrest release on the inner
    side
    Base engine T8C 4-cylinder gasoline engine 1.8 L
    unit 06A.C
    Batteries J1L Battery 280 A (60 Ah)
    Body measures 5C0 Without special body measures
    Body style K8C Coupe
    Brake pad wear indicator 9U0 Without brake pad wear indicator
    Brake type, front 1LT Disc brakes, front
    Brake type, rear 1KK Disc brakes, rear
    Braking systems 1AJ Anti-spin regulation (ABS/ASR/EDL) with
    electronic differential lock (EDL)
    Carrier frequency for radio remote control 5D1 Trägerfrequenz 433,92 MHz
    CD changer/CD player 7A0 Without CD changer/CD player
    Cd enhancing underbody panel 2D1 Complete cd enhancing underbody panel
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    Center armrest 6E0 Without center armrest front
    Component part sets with country-specific design requirements B0A Component parts set without
    Cruise control 8T0 Without cruise control system (CCS)
    Cup holder 4M0 Without cup holder
    Delivery equipment 2A4 Delivery equipment for shipment (transit
    coating) with thick seat cover
    Door and lid locking system 4K4 Zentralverriegelung m. Funkfernbedienung
    Innenbetätigung und separater
    Kofferraumentriegelung
    Doors 0A1 2 doors
    Drive layout 1X0 Front wheel drive
    Engine cooling system 8Z6 Motorkühlung Ausführung 2
    Engine specifications MV0 4-cyl. gasoline engine 1.8 L/132 kW 20V
    turbo, EU 3D
    base engine is T8C
    Equipment levels A8S Standard equipment
    Exterior mirror setting 6XD Exterior mirrors: electrically
    adjustable/heated
    Exterior noise suppression measures 2B1 Additional exterior noise suppression
    First aid kit / warning triangle 1T3 First aid kit with warning triangle
    Fresh air intake for passenger compartment (with particulate filter) 2V1 Dust and pollen filter
    Front license plate carrier 6W5 Front license plate bracket
    Front seats Q1D Sports front seats
    Front stabilizer 0AN Stabilizer, front
    Fuel filler cap/door, locking option 2W0 Fuel filler cap
    Fuel quantity for initial filling 1Z0 Initial standard fuel filling
    Fuel systems 0F2 Fuel system for carburetor gasoline
    engine
    Fuel tank treatment 2LB Kraftstoffbehälter mit besonderer
    Werkstoffbehandlung (Fluorierung)
    Gearshift boot/cover 6R3 Rubber gearshift boot
    Gearshift knob/handle 6Q7 Leather gearshift knob with aluminum
    appearance
    General operating permit, alterations C02 Operating permit, alteration
    Generators 8GD Alternator 90A
    Handling standard production and pre-production series FA0 Control of standard production
    Hardtop 5F0 Without hardtop
    Headlight 8BG Twin-headlight for driving on the right,
    with integrated high beam
    Headlight activation 8K0 Without special headlight
    activation
    Headlight washer system 8X0 Without headlight washer system
    Headlight-range adjustment 8Q1 Headlight-range adjustment
    Heat accumulator system/additional heater 7E0 W/o heat accumulator/auxiliary heating
    Heated washer nozzles 9T1 Heated washer nozzles, front
    Heating and air conditioning system 9AK Climatronic with impact pressure
    control free of cfc
    Horns 8Y1 Two-tone horn
    Identification plates 1EX Spezielles Typschild für EG
    Ignition/starter switch locking system 0RA Without ignition/starter switch locking
    system
    Insert for the filling up of unleaded fuel/fuel type 2G9 Filler neck module 2 with insert
    Instrument inserts U1A Instrument insert with km/h speedometer,
    clock, tachometer and trip odometer
    Label for central electric 0W1 Label for central electric
    German-speaking countries
    Label for radio remote control 7CA Without label for radio remote control
    Left exterior mirror 5SL Left exterior mirror: aspherical
    Left vanity mirror 4SD Left vanity mirror, illuminated
    Lock operation for tailgate/trunk lid 4E6 Entriegelung Heckklappe/Deckel nur von
    innen
    Lockable wheel bolts 1PC Wheel bolts with anti-theft protection
    (unlockable)
    Lumbar support 7P0 Without lumbar support
    in seat backrests
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    Mud flap 6N0 Without mud flaps
    Multi-function display/trip computer 9Q2 Multi-function display/on-board computer
    with check control
    Navigation device 7Q0 Without navigation device
    Outdoor temperature gage 9Y1 Outdoor temperature gage
    Owner's manuals 0VG Information kit in Italian
    Paint preservative/transit coating 5K5 Transportschutzfolie
    (anstelle Lackkonservierung)
    Park distance control 7X0 Ohne Einparkhilfe (Parkpilot)
    Platform module floor pan, rear 4P0 Rear floor panel module, type 1
    Preparation for two-way radio installation 9D0 Without preparation for two-way radio
    installation
    Proportioning valve 1H0 Without proportioning valve
    Radios 8UC Radio "chorus"
    Rear axle 0N5 Standard rear axle
    Rear fog light 8TC Rear fog light for driving on the right
    Rear stabilizer 0BD Rear stabilizer
    Rear trim panel 6V1 Rear trim panel (ECE)
    Rear window wiper and washer system 8M0 W/o rear window wiper and washer system
    Right exterior mirror 5RQ Right exterior mirror: convex
    Right vanity mirror 4TD Right vanity mirror illuminated
    Roof insert/convertible top 3FA Without roof insert (standard roof)
    Safety certificate 0LK Special plates/stickers/
    safety certificates for Italy
    Seat adjustment 3L3 Manual height adjustment for front seats
    Seat belt check 9P0 Without seat belt reminder
    Seat covering N5D Valcona leather seat covering
    Seat heater 4A3 Seat heater for front seats
    separately controlled
    Service interval prolongation QG0 Without service interval prolongation
    Shock absorption, chassis, front 1GS Front shock absorption (AUDI TT)
    Shock absorption, chassis, rear 1JE Rear sports shock absorption
    Side air bag 4X1 Side air bag front
    Side lights 8F2 Side turn signal lights
    Smoking/non-smoking package 9JD Smoking package, ashtray front
    Spare wheel/breakdown set 1G9 Space-saving spare wheel for temporary
    use, radial tire
    (5-hole)
    Speaker installation 9VD Speaker (active)
    Special editions E0A No special edition
    Special labels/plates 0SU Labels/plates in Spanish and Italian
    Speedometer cable and seal 8CC Speedometer sensor without seal
    (electronic speedometer sensor)
    Start/stop system/regenerative braking 7L0 Without inertia benefit system/
    deceleration fuel cut-off/idle stop
    valve
    Steering 1N4 Servolenkung
    (andere Übersetzung)
    Steering column systems 2C5 Axial and vertical adjustable steering
    column
    Steering system arrangement L0L Left-hand drive vehicle
    Steering wheels 2ZN Leather trimmed sports steering wheel
    with aluminum appearance
    Telephone/telematics 9W0 W/o car phone preparation/installation
    Throttle actuation 0L2 Electric throttle actuation
    Tires H6G Tires 225/45 ZR17 91Y
    Tool kit and jack 1S7 Tool kit and aluminum jack
    Trailer hitch 1D0 Without trailer hitch
    Transmission shafts 1WB Transmission shafts w/ 100 mm in
    diameter
    Transmission shafts, rear axle 1YA Without transmission shafts f. rear axle
    Transmission specifications G0C 5-speed manual transmission
    Transmission types/gearshift mechanisms 0G4 Cable gearshift
    Type approval countries/countries with special requirements B99 Type approval EC
    Type sign 2Z1 Type sign at rear
    and "Quattro" nameplates respectively
    Vehicle class differentiation units/platform components 0CV Vehicle class differentiation 8N0
    Vehicle specifications F0A No special purpose vehicle, standard
    equipment
    Washer fluid level indicator 8W1 Washer fluid level indicator
    Weight category front axle U99 Suspension range 198
    Weight category rear axle 0YC Weight range 3
    installation control only, no
    requirement forecast
    Wheels C4N Alloy wheels 7.5J x 17
    Wind blocker 7S0 Without wind blocker
    Window regulator 4R1 Power windows
    Windshield glass type 4GH Windshield in heat-insulating glass
    with sunshield
    Windshield wiper intermittent control/ light/rain sensor 8N4 Windshield wiper intermittent control
    with potentiometer (four speeds)
    PI1 Driver Information System (DIS)
    PRS 4 cast aluminium alloy wheels 7.5Jx17
    in6-arm design with tyres 225/45 R 17 Y
  1. Rozkodowanie wyposażenia po VIN, jak ?
    Przez Ernest w dziale Ogólne
    Ostatni post / autor: 07-06-2016, 17:41
  2. MK1 [8N] witam proszę o waszą opinie oraz rozkodowanie vin
    Przez Koko w dziale Porady przy kupnie Audi TT
    Ostatni post / autor: 17-02-2016, 15:11
  3. MK1 [8N] witam proszę o waszą opinie oraz rozkodowanie vin
    Przez el1977 w dziale Porady przy kupnie Audi TT
    Ostatni post / autor: 12-01-2016, 11:28
  4. Bardzo proszę o foto.
    Ostatni post / autor: 03-10-2011, 12:45
  5. Logi 180 Quattro bardzo proszę o interpretację
    Przez Cubanito w dziale VAG-COM
    Odpowiedzi: 29
    Ostatni post / autor: 02-10-2011, 05:54
