poprawiam wpis bo to co wkleilem jakas pomylka byla.....
zaraz dodam poprawne odczyty
dobra pany nie wiem czy cokolwiek robie dobrze ale tak :
czy to sa logi statyczne ?
i czy wogole to jest potrzebne do czegos ?
pruboje to skonvertowac przez csv.conv ale jakies dziwne te tabelki wychodza....
Thursday,29,May,2014,16:35:12:62939
VCDS Version: Release 11.11.6
Data version: 20121223
Adaptation Channel 001:
Stored value 128
Test value 128
Idle Speed Adjustment
750 /min Engine Speed (actual)
780 /min Engine Speed (specified)
A/C-Low A/C Readiness
Compr.OFF A/C Compressor
Thursday,29,May,2014,19:01:20:62939
Address 01: Engine (8N0 906 018 CB)
19:01:16 Group 098
Bin. Bits
Bin. Bits
Bin. Bits
Bin. Bits
19:01:16 Group 004: General
800 /min Engine Speed (G2
14.070 V Battery Voltage (Terminal 30)
55.0°C Coolant Temperature (G62)
41.0°C Intake Air Temperature (G42)
19:01:16 Group 008: General (Brake System - Automatic Transmission only)
Not Oper. Brake Pedal Status
Brake System Vacuum Pump (V192)
80.0 mbar Brake Booster Pressure
Brake Booster Test Result
Thursday,29,May,2014,19:12:23:62939
19:12:04 Group 002: General
760 /min Engine Speed (G2
12.0 % Engine Load
2.04 ms Injection Timing
1.94 g/s Mass Air Flow Sensor (G70)
Thursday,29,May,2014,19:12:58:62939
19:12:56 Group 003: General
2.00 g/s Mass Air Flow Sensor (G70)
3.1 % Throttle Valve Angle
8.3 °BTDC Ignition Timing Angle
Thursday,29,May,2014,19:13:18:62939
19:13:16 Group 005: General
12.8 % Engine Load
0.0 km/h Vehicle Speed
Idle Load Status
Thursday,29,May,2014,19:13:31:62939
19:13:29 Group 006: General
12.8 % Engine Load
-1.6 % Altitude Correction Factor
Thursday,29,May,2014,19:13:51:62939
19:13:50 Group 010: Ignition
12.8 % Engine Load
2.7 % Throttle Valve Angle
9.8 °BTDC Ignition Timing Angle
Thursday,29,May,2014,19:14:05:62939
19:14:04 Group 011: Iginition
69.0°C Coolant Temperature (G62)
40.0°C Intake Air Temperature (G42)
10.5 °BTDC Ignition Timing Angle
Thursday,29,May,2014,19:14:32:62939
19:14:31 Group 014: Ignition (Misfire Recognition - Total)
12.0 % Engine Load
0 Misfire Counter
Disabled Misfire Recognition
Thursday,29,May,2014,19:16:14:62939
19:16:13 Group 022: Ignition (Timing Retardation Cylinder 1 && 2)
11.3 % Engine Load
0.0°KW Timing Retardation Cylinder 1
0.0°KW Timing Retardation Cylinder 2
Thursday,29,May,2014,19:17:07:62939
19:17:06 Group 026: Ignition (Knock Control Cylinder 1-4)
0.702 V Knock Sensor Voltage Cylinder 1
0.819 V Knock Sensor Voltage Cylinder 2
0.702 V Knock Sensor Voltage Cylinder 3
0.819 V Knock Sensor Voltage Cylinder 4
Thursday,29,May,2014,19:18:56:62939
19:18:54 Group 033: Lambda Control
-1.6 % Lambda Control Bank 1 Sensor 1
1.300 V Sensor Voltage Bank 1 Sensor 1
Bin. Bits
Bin. Bits
Thursday,29,May,2014,19:19:07:62939
19:19:06 Group 032: Lambda Control (Mixture Adaptation)
4.7 % Adaptation (Idle) Bank 1 Sensor 1
0.0 % Adaptation (Partial) Bank 1 Sensor 1
Bin. Bits
Bin. Bits
Thursday,29,May,2014,19:19:18:62939
19:19:17 Group 031: Lambda Control (Lambda Sensor Voltages)
0.953 Lambda Control Bank 1 (actual)
0.953 Lambda Control Bank 1 (specified)
Bin. Bits
Bin. Bits
Thursday,29,May,2014,20:48:20:62939
20:48:18 Group 012
Bin. Bits
Bin. Bits
Bin. Bits
Bin. Bits
20:48:18 Group 011: Iginition
76.0°C Coolant Temperature (G62)
39.0°C Intake Air Temperature (G42)
11.3 °BTDC Ignition Timing Angle
20:48:18 Group 010: Ignition
11.3 % Engine Load
2.4 % Throttle Valve Angle
13.5 °BTDC Ignition Timing Angle
Thursday,29,May,2014,20:49:18:62939
20:49:16 Group 020: Ignition (Timing Retardation Cylinder 1-4)
0.0°KW Timing Retardation Cylinder 3
0.0°KW Timing Retardation Cylinder 4
20:49:16 Group 023: Ignition (Timing Retardation Cylinder 3 && 4)
11.3 % Engine Load
20:49:16 Group 022: Ignition (Timing Retardation Cylinder 1 && 2)
11.3 % Engine Load
Thursday,29,May,2014,20:49:46:62939
20:49:45 Group 026: Ignition (Knock Control Cylinder 1-4)
0.819 V Knock Sensor Voltage Cylinder 3
20:49:45 Group 028: Ignition (Knock Sensor Test)
11.3 % Engine Load
78.0°C Coolant Temperature (G62)
Test OFF Knock Sensor Test Result
20:49:45 Group 030: Lambda Control (Sensor Status)
011 Bank 1 Sensor 1
000 Bank 1 Sensor 2
Bin. Bits
Bin. Bits
Thursday,29,May,2014,20:50:12:62939
20:50:10 Group 033: Lambda Control
-3.9 % Lambda Control Bank 1 Sensor 1
1.320 V Sensor Voltage Bank 1 Sensor 1
Bin. Bits
Bin. Bits
20:50:10 Group 032: Lambda Control (Mixture Adaptation)
4.1 % Adaptation (Idle) Bank 1 Sensor 1
Bin. Bits
Bin. Bits
20:50:10 Group 031: Lambda Control (Lambda Sensor Voltages)
0.938 Lambda Control Bank 1 (actual)
Bin. Bits
Bin. Bits
Thursday,29,May,2014,20:50:33:62939
20:50:31 Group 034: Lambda Control (Aging Check: Bank 1 Sensor 1)
255.0°C Catalytic Converter Bank 1 Temp.
1.000 Dynamic Factor Bank 1 Sensor 1
Test OFF Result Lambda Aging
20:50:31 Group 037: Lambda Control (Delta Lambda Bank 1)
11.3 % Engine Load
0.465 V Sensor Voltage Bank 1 Sensor 2
0.000 Adjustment Bank 1 Sensor 2
Test OFF Result Delta Lambda B1
20:50:31 Group 036: Lambda Control (Sensor Readiness - After Catalyst)
0.470 V Sensor Voltage Bank 1 Sensor 2
Test OFF Result Lambda Availability
Bin. Bits
Bin. Bits
Thursday,29,May,2014,20:51:09:62939
20:51:08 Group 046: Lambda Control (Catalytic Conversion Test Bank 1)
15.0°C Catalytic Converter Bank 1 Temp.
0.13 Catalytic Conversion Bank 1
Test OFF Cat. Conversion Test Bank 1
20:51:08 Group 041: Lambda Control (Lambda Sensor Heating Bank 1)
Resistance Bank 1 Sensor 1
Htg. S1 OFF Heater Condition Bank 1 Sensor 1
Resistance Bank 1 Sensor 2
Htg. S2 OFF Heater Condition Bank 1 Sensor 2
20:51:08 Group 043: Lambda Control (Aging Check: Bank 1 Sensor 2)
0.475 V Lambda Voltage Bank 1 Sensor 1
Test OFF Lambda Sensor Aging Test B1S2
Thursday,29,May,2014,20:51:39:62939
20:51:38 Group 053: Idle Speed Stabilization (Generator Load)
760 /min Engine Speed (actual)
760 /min Engine Speed (specified)
14.000 V Battery Voltage (Terminal 30)
47.1 % Generator Load
20:51:38 Group 051: Idle Speed Stabilization (Gear shifts)
0 Selected Gear
20:51:38 Group 050: Idle Speed Stabilization
Thursday,29,May,2014,20:51:58:62939
20:51:56 Group 054: Idle Speed Stabilization
Idle Load Status
0.0 % Accel. Pedal Pos. Sensor 1 (G79)
20:51:56 Group 055: Idle Speed Stabilization
0.0 % Idle Regulator
-0.4 % Idle Stabilization Self-Adaptation
00000 Operating Condition
20:51:56 Group 056: Idle Speed Stabilization
Thursday,29,May,2014,20:52:20:62939
20:52:18 Group 062: Electronic Throttle (Sensor Values)
12.5 % Throttle Valve Sensor 1 (G187)
87.5 % Throttle Valve Sensor 2 (G18
14.8 % Accel. Pedal Pos. Sensor 1 (G79)
7.0 % Accel. Pedal Pos. Sensor 2 (G185)
20:52:18 Group 061: Electronic Throttle
20:52:18 Group 060: Electronic Throttle (Throttle Body Alignment)
0 Throttle Valve Steps Counter
ADP. O.K. Throttle Body Alignment Status
Thursday,29,May,2014,20:52:47:62939
20:52:45 Group 063: Electronic Throttle (Kick-Down Alignment)
Kick-Down Alignment Value
Kick-Down Switch
Kick-Down Alignment Status
20:52:45 Group 064: Electronic Throttle (Sensor Adaption Values)
0.540 V Lower Adaptation Sensor 1 (G187)
4.580 V Lower Adaptation Sensor 2 (G18
0.760 V Emergency Air Gap Sensor 1 (G187)
4.360 V Emergency Air Gap Sensor 2 (G18
20:52:45 Group 070: Emission Reduction (EVAP Valve Test)
4.3 % Evap. Emissions Sol. Valve (Open)
7.0 % Lambda Control
Evap. Emissions Sol. Valve (Flow)
EVAP OK EVAP Valve Test
Thursday,29,May,2014,20:53:57:62939
20:53:56 Group 090: Camshaft Adjustment (Intake)
OFF Cam. Adjustment Intake Status
-1.0°KW Cam. Adjustment Intake B1 (act.)
Bin. Bits
20:53:56 Group 091: Camshaft Adjustment (Bank 1 Intake)
11.3 % Engine Load
0.0°KW Cam. Adjustment Intake B1 (act.)
20:53:56 Group 093: Camshaft Adjustment Adaptation
11.3 % Engine Load
-3.0°KW Phase Position Bank 1 Intake
Bin. Bits
Thursday,29,May,2014,20:54:49:62939
20:54:47 Group 102: Fuel Injection
88.0°C Coolant Temperature (G62)
42.0°C Intake Air Temperature (G42)
1.70 ms Injection Timing
20:54:47 Group 101: Fuel Injection
11.3 % Engine Load
1.61 g/s Mass Air Flow Sensor (G70)
20:54:47 Group 094: Camshaft Adjustment (Intake)
Cam Ctrl. ON Cam. Adjustment Intake Status
Test OFF Cam. Adj. Test Bank 1 Intake
Bin. Bits
Thursday,29,May,2014,20:55:34:62939
20:55:33 Group 107: Fuel Injection (Fuel Supply System)
-0.8 % Lambda Control Bank 1
Bin. Bits
Test OFF Result Lambda Control
20:55:33 Group 113: Load Registration (Load/Full Throttle Enrichment)
11.3 % Engine Load
1005.0 mbar Athmospheric Pressure
20:55:33 Group 112: Exhaust Gas Temperature
295.0°C Exhaust Gas Temperature Bank 1
0.0 % Enrichment Factor Sensor Bank 1
Bin. Bits
Bin. Bits
Thursday,29,May,2014,20:56:02:62939
20:56:00 Group 114: Charge Pressure Control
96.2 % Engine Load (specified)
95.5 % Engine Load (spec. corrected)
11.3 % Engine Load (actual Value)
0.0 % Boost Pressure Control (N75)
20:56:00 Group 116: Charge Pressure Control
0.0 % Correction Factor Fuel
0.0 % Correction Factor Coolant Temp.
0.0 % Intake Air Temp. Correction Factor
Thursday,29,May,2014,20:56:30:62939
20:56:29 Group 119: Charge Pressure Control
0.0 % Boost Pressure Control Adapt.
1010.0 mbar Boost Pressure (actual)
20:56:29 Group 118: Charge Pressure Control
20:56:29 Group 117: Charge Pressure Control
2.4 % Throttle Valve Sensor 1 (G187)
1000.0 mbar Boost Pressure (specified)
Thursday,29,May,2014,20:58:27:62939
20:58:25 Group 208
11.3 % Load
22.6 % Load
0 Count
HL
20:58:25 Group 206
1.67 g/s Mass Flow
2.64 g/s Mass Flow
0.77 (no units)
1010.0 mbar Absolute Pres.
20:58:25 Group 204
2.4 % Load
0.0 % Lambda
-0.2 % Lambda
0.8 % Lambda
Thursday,29,May,2014,20:58:46:62939
20:58:44 Group 208
11.3 % Load
22.6 % Load
0 Count
HL
20:58:44 Group 206
1.69 g/s Mass Flow
2.67 g/s Mass Flow
0.77 (no units)
20:58:44 Group 204
2.7 % Load
0.0 % Lambda
-0.2 % Lambda
1.6 % Lambda
Thursday,29,May,2014,20:59:21:62939
20:59:19 Group 209
-0.2 % Lambda
-2.1 % Lambda
0.0 % Lambda
0.0 % Lambda
20:59:19 Group 206
1.67 g/s Mass Flow
2.64 g/s Mass Flow
0.77 (no units)
20:59:19 Group 213
760 /min RPM
11.3 % Load
0.953 Lambda Factor
1.000 Lambda Factor
Thursday,29,May,2014,21:04:20:62939
Address 22: AWD (02D 900 554 C)
21:04:19
LO Haldex Clutch Pump
Thursday,29,May,2014,21:05:04:62939
21:05:02
Not Oper. Brake Light Switch -F-
Activated Parking Brake Switch -F9-
12.90 V Voltage supply
Thursday,29,May,2014,20:46:35:62939
20:46:24 Group 001: General
71.0°C Coolant Temperature (G62)
10111110 Basic Setting Requirements
20:46:24 Group 003: General
1.97 g/s Mass Air Flow Sensor (G70)
6.0 °BTDC Ignition Timing Angle
20:46:24 Group 002: General
12.8 % Engine Load
Thursday,29,May,2014,20:47:10:62939
20:47:01 Group 004: General
73.0°C Coolant Temperature (G62)
20:47:01 Group 005: General
12.0 % Engine Load
Idle Load Status
20:47:01 Group 006: General
12.0 % Engine Load
