niemal pierwsze zdania z tematu:
"I have a problem with the pipe shown here, the seemingly infamous turbo outlet to pancake connecting pipe..."
"...I'm still blowing from there, fuel trims are 0.4% and -16.4% just 10 miles after re-setting. I have the Forge boost hoses, all connections are tight. I also have a checkvalve under the mani before the PCV. Most vac lines are replaced recently. I believe it's this pipe as everytime I check, it's loose, and is coated in oil film"
nie chce zapeszac, ale chyba idziemy w dobrym kierunku...
... pozostaje wybor rozwiazania do usuniecia nieszczelnosci, etka pokazuje, ze mam w aucie rozwiazanie z pierwszego obrazka, czyli rura o nr 06A 145 790C
LinkBack URL
About LinkBacks
Odpowiedź z Cytatem
