jak w temacie
Keep LED DRL's on With Turn Signals
[09 – Cent. Elect.]
[Coding - 07] -> [Long Coding Helper] -> Byte 3 Bit 7 - Change 1 to 0
Turn off amber side markers (US models Only) [09 – Cent. Elect.]
[Coding - 07] -> [Long Coding Helper] -> Byte 10 Bit 3 - Change 1 to 0
Front Fog Lights stay on with High-beams ** [09 – Cent. Elect.]
[Coding - 07] -> [Long Coding Helper] -> Byte 4 Bit 1 - Change 1 to 0
Rear Fog Lights stay on with High-beams ** [09 – Cent. Elect.]
[Coding - 07] -> [Long Coding Helper] -> Byte 4 Bit 2 - Change 1 to 0
Headlights on all the time ** [09 – Cent. Elect.]
[Coding - 07] -> [Long Coding Helper] -> Byte 4 Bit 5 - Change 0 to 1
Fog Light turns on with turn signal (Curb Side Lighting)** [09 – Cent. Elect.]
[Coding - 07] -> [Long Coding Helper] -> Byte 4 Bit 0 - Change 0 to 1
*Headlights must be on without Fog Lights for this to work.
Front Turn Signals as Parking lights ** [09 – Cent. Elect.]
[Coding - 07] -> [Long Coding Helper] -> Byte 10 Bit 0 - Change 0 to 1
Once the change has been made you can enable the front turn signals as DRL's by making the following change
[09 – Cent. Elect.]
[Coding - 07] -> [Long Coding Helper] -> Byte 2 Bit 6 - Change 0 to 1
Emergency Brake Flashing Lights This change allows the brake lights to flash rapidly in the event of emergency braking.
[46 - Comfort System]
[Coding - 07] -> [Long Coding Helper] -> Byte 8:
Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
I have not been able to confirm this working on my own car although it is coded. I have seen video's of people who have enabled this though and it's cool feature. During emergency braking your brake lights strobe momentarily before going solid.
Adjust LED Brightness This will allow you to change the intensity of the LED's when your headlights are on. By default the LED's are only 8-9% or brightness.
[09 – Cent. Elect.]
[Security Access - 16] (enter security code. One of the default codes is- 20113)
[Adaptation - 10] -> Channel 3
Enter new value for LED brightness i.e. "100" If you want LED's at 100%.
Values bellow 5 turns the LED's off and generates an error code and warning in DIS .
Keep LED's at Full Brightness with Parking Lights
This will stop the LED's from dimming when the parking lights are turned on.
[09 – Cent. Elect.]
[Coding - 07] -> [Long Coding Helper] -> Byte 3: Bit 2 - Change 0 to 1
