Witam po ponownym przeskanowaniu TT pojawiły mi sie następujące błędy:
VAG-COM Version: Release 311.2-N
Chassis Type: 8N - Audi TT
Controller: 8N0 906 018 AB
Component: 1.8L R4/5VT 0002
Coding: 05500
Shop #: WSC 76139
4 Faults Found:
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
P1113 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
16622 - Manifold Pressure / Boost Sensor (G31): Signal too High
P0238 - 35-10 - - - Intermittent
Readiness: 0000 0000
Controller:
Component: Zentralverrieg.,DWA D01
Coding: 32767
Shop #: WSC 131071
72 Faults Found:
01366 - Opened Due to Crash Signal
01371 - Alarm triggered by Door Contact Switch: Driver's Side
01572 - Alarm triggered by Door Contact Switch: Passenger Side
01374 - Alarm triggered by Terminal 15
01370 - Alarm triggered by Interior Monitoring
01369 - Alarm triggered by Hood Switch
01368 - Alarm triggered by Luggage Compartment Switch
01373 - Alarm triggered by Radio Ground Contact
01558 - Contact Switch in Locking Cyl: Driver Side: Close (F241)
29-10 - Short to Ground - Intermittent
01557 - Contact Switch in Locking Cyl: Driver Side: Open (F241)
00000 - End of Output
00-10 - - - Intermittent
01563 - Interior Lock Switch: Driver Side (E150): Lock
01564 - Interior Lock Switch: Driver Side (E151): Unlock
00947 - Trunk Lid remote Control Switch (E18
01565 - Luggage Compartment Light (W3)
28-10 - Short to B+ - Intermittent
00668 - Supply Voltage Terminal 30
07-10 - Signal to Low - Intermittent
00991 - Interior Lights
01616 - Signal Wire to Interior Monitor
36-10 - Open Circuit - Intermittent
01568 - Signal for Convenience Opening
01569 - Signal for Convenience Closing
01357 - Tank Flap Locking Motor (V155)
01555 - Motors for Central Locking: Save [Safe?]
01556 - Motors for Central Locking: Unlock
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
00956 - Key 2
00957 - Key 3
00958 - Key 4
01570 - Turn-Off Delay: Terminal 15
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
01560 - Passenger Door
59-10 - Can't Unlock - Intermittent
60-10 - Won't Safe - Intermittent
61-10 - Won't De-Safe - Intermittent
01552 - Motor for Central Locking: Drivers Door (V56): Lock
01553 - Motor for Central Locking: Passenger Door (V57): Lock
01554 - Motors for Central Locking: Rear Doors: Lock
00949 - Central Locking Motor - tailgate (V53): LOCK
00849 - S-contact at Ignition/Starter Switch (D)
31-10 - Open or Short to Ground - Intermittent
01581 - Incorrect Component Detected
01379 - Interior Monitor Switch (E183)
30-10 - Open or Short to B+ - Intermittent
01482 - Motors for Central Locking
01617 - Please Check DTC Memory of Interior Monitoring
00-00 - -
Skasowałem błędy sondy, jeżeli pojawią się na nowo to znaczy że sonda definitywnie do wymiany tak?
Tu przestroga dla tych którzy zastanawiają sie czy kupić Boscha czy zamiennik, bo sondę mam może ze 2 miesiące
1. co oznacza błąd: 16622 ?
2. mam mnóstwo błędów związanych z centralnym zamkiem, chociaż dziś udało mi sie go przekodować właśnie tak jak chciałem, czyli potwierdzenie otwarcia-zamknięcia mignięciem kierunków itp.![]()
Dużo się z tym bawiłem bo nie mogłem sie zalogować do mod. komfortu ale pomógł link od Arttura- wielkie dzięki
Ale do rzeczy czy tymi błędami mimo że są mam sie nie przejmować?
3. co oznacza błąd : 01617 - Please Check DTC Memory of Interior Monitoring
Z góry wielkie dzięki za pomoc- Pozdrawiam!
