Wczoraj znalazłem chwilę po pracy, więc zrobiłem szybki skan auta i trochę szczęka mi opadła... No żesz .... (tutaj był wulgaryzm, ale już nawet nie mam siły na wulgaryzmy).
Address 45 -------------------------------------------------------
Controller: 8N7 951 177
Component: Innenraumueberw. D15
Coding: 00001
Shop #: WSC 00000
1 B31d Zapis.:
01463 - Alarm triggered by Sensor for anti-theft alarm System
43-00 - Closed
Address 35 -------------------------------------------------------
Controller: 8N7 962 267 C
Component: Zentralverrieg.,DWA D06
Coding: 07002
Shop #: WSC 01236
4 Znalezione:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01559 - Drivers Door
60-00 - Won't Safe
01134 - Alarm Horn (H12)
49-00 - No Communications
01091 - Switch Front Canopy (F202)
27-10 - Implausible Signal - Intermittent
Address 22 -------------------------------------------------------
Controller: 02D 900 554 D
Component: HALDEX LSC ECC 0011
1 B31d Zapis.:
00526 - Brake Light Switch-F
Address 17 -------------------------------------------------------
Controller: 8N1 920 900
Component: KOMBI+WEGFAHRS. M73 D12
Coding: 05144
Shop #: WSC 00077
XXXXXXXXXXXXXXXXX
1 B31d Zapis.:
01336 - Data Bus for Comfort System
37-10 - Faulty - Intermittent
Address 08 -------------------------------------------------------
Controller: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00041
Shop #: WSC 01236
1 B31d Zapis.:
00792 - A/C Pressure Switch (F129)
31-10 - Open or Short to Ground - Intermittent
http://wiki.ross-tech.com/wiki/index.php/01463
http://wiki.ross-tech.com/wiki/index.php/01370
http://wiki.ross-tech.com/wiki/index.php/01559
http://wiki.ross-tech.com/wiki/index.php/01134
01091 - Switch Front Canopy (F202) - http://www.audifans.net/ftopic-34798-0.html
http://wiki.ross-tech.com/wiki/index.php/00526
http://wiki.ross-tech.com/wiki/index.php/01336
http://wiki.ross-tech.com/wiki/index.php/00792
To teraz tak, zaraz zagłębię się w lekturach o tych problemach i zacznę to wszystko sprawdzać (wiem że sporo tematów padło na forum, więc zaraz to poszukam i poczytam). Czy któryś z tych błędów jest KRYTYCZNY? Wiem że czujnik od stopu jeszcze dziś chcę zamówić by wymienić, ale czy coś jeszcze jest mega pilne (nie może poczekać do przyszłego tygodnia)?
A największa ironia? Auto po wizycie u Pawła jeździ duuuuużo lepiej, a nawet najlepiej odkąd je kupiłem
