Pokaż wyniki od 1 do 7 z 7
Wątek: TT quattro logi - co z tym zrobic ?
    Aug 2014
    11
    Monday,04,August,2014,15:14:03:14533
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.2.0
    Data version: 20140212
    VIN: License Plate: BARTEK
    Mileage: 182420km-113350mi Repair Order:
    Chassis Type: 8N - Audi TT (1999 > 2007)
    Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
    Mileage: 182420km/113350miles
    Address 01: Engine Labels: 06A-906-032-APX.clb
    Part No: 8N0 906 018 F
    Component: 1.8L R4 5VT 0003
    Coding: 05610
    Shop #: WSC 12599
    VCID: 346D20B50403AABE4FF-5140
    2 Faults Found:
    17830 - Secondary Air Injection Solenoid Valve (N112)
    P1422 - 35-00 - Short to Plus
    17947 - Clutch Pedal Switch (F36)
    P1539 - 35-00 - Implausible Signal
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 8N0-907-379-MK20.lbl
    Part No: 8N0 907 379 A
    Component: ABS/EDS 20 IE CAN V001
    Coding: 13504
    Shop #: WSC 01236
    VCID: 3A710E8D26675CCE953-4AEA
    No fault code found.
    Address 08: Auto HVAC Labels: 8N0-820-043.lbl
    Part No: 8N0 820 043
    Component: TT-KLIMAVOLLAUTOMAT D02
    Coding: 00041
    Shop #: WSC 01236
    VCID: E7D707F985559126BAD-2582
    Address 15: Airbags Labels: 8N8-909-601.lbl
    Part No: 8N8 909 601
    Component: Airbag Front+Seite 1005
    Coding: 10102
    Shop #: WSC 01236
    VCID: F7F757B9D5F501A62AD-5122
    Address 17: Instruments Labels: 8Nx-920-xxx-17.lbl
    Part No: 8N2 920 930
    Component: KOMBI+WEGFAHRS. M73 D24
    Coding: 04444
    Shop #: WSC 131071
    VCID: EFE76FD9ADA54966F2D-4AEA
    Subsystem 1 - Part No: Ident
    Component: Nr. Wegfahrs.:AUZ5Z0X9253297
    Ident.-Nr. Wegfahrs.:AUZ5Z0X9253297
    Address 22: AWD Labels: 02D-900-554.lbl
    Part No: 02D 900 554 B
    Component: HALDEX LSC ECC 0006
    VCID: 1F47DF199D8519E682D-4AEA
    Address 35: Centr. Locks Labels: 8Nx-962-267.lbl
    Part No: 8N8 962 267 B
    Component: Central Lock/Alarm D04
    Coding: 04810
    Shop #: WSC 01236
    VCID: 40857C6540BB061EDB7-4ECE
    4 Faults Found:
    35-00 - -
    36-10 - Open Circuit - Intermittent
    01134 - Alarm Horn (H12)
    49-00 - No Communications
    01617 - Please Check DTC Memory of Interior Monitoring
    35-10 - - - Intermittent
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8N8 951 177
    Component: Innenraumueberw. D09
    Coding: 00001
    Shop #: WSC 00000
    VCID: FCFD4895ECD322FE47F-51B6
    1 Fault Found:
    01463 - Alarm triggered by Sensor for anti-theft alarm System
    35-00 - -
    Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
    Part No: 4B0 907 357
    Component: LEUCHTWEITEREGLER D003
    Coding: 00010
    Shop #: WSC 01236
    VCID: E5CB0DF17F598336881-51B6
    Address 56: Radio Labels: 8D0-035-1xx-56.lbl
    Part No: 4B0 035 186 D
    Component: Radio 0001
    Coding: 00517
    Shop #: WSC 01236
    VCID: 2143D9E1ABF12F16B49-4B04
    1 Fault Found:
    00852 - Loudspeaker(s); Front
    36-00 - Open Circuit
    7,038
    Chyba odczyt bledow...skasuj i zobacz co wroci.
    Aug 2014
    11
    po wykasowaniu i ponownym sprawdzeniu wrocilo
    Log-BARTEK 2-182420km-113350mi.txt
    Monday,04,August,2014,15:39:57:14533
    VIN: License Plate: BARTEK 2
    Coding: 05610
    Shop #: WSC 12599
    VCID: 346D20B50403AABE4FF-515C
    1 Fault Found:
    Coding: 13504
    Shop #: WSC 01236
    Coding: 00041
    Shop #: WSC 01236
    Coding: 10102
    Shop #: WSC 01236
    VCID: F7F757B9D5F501A62AD-5140
    Coding: 04844
    Shop #: WSC 131071
    VCID: EFE76FD9ADA54966F2D-4B04
    Coding: 04810
    Shop #: WSC 01236
    4 Faults Found:
    35-00 - -
    Coding: 00001
    Shop #: WSC 00000
    Coding: 00010
    Shop #: WSC 01236
    VCID: E5CB0DF17F598336881-5198
    Coding: 00517
    Shop #: WSC 01236
    VCID: 2143D9E1ABF12F16B49-4AEA
    1 Fault Found:
    End ---------------------------------------------------------------------
    Wyświetlanie Log-BARTEK 2-182420km-113350mi.txt.
    Awatar Elor
    May 2011
    IRL
    00
    00
    00
    1,356
    SAI ci sie popsuło, coś z czujkami alarmku i głosnik z przodu, będzie jak nic u Matee do odkupienia :P
    Aug 2014
    11
    dzieki - ciezko bedzie z wysylka do irlandii , czy ktos moglby podac mi jakis numerek po ktorym bede mogl poszukac w tutejszych sklepach ? pewnie majatku nie ksoztuje
    co do alarmu to mam go w nosie , przez 4ty lata samochodu nie zamykam wcale i jest ok :P , natomiast glosnik poczeka jak bede mial chwilke wiecej czasu
    7,038
    Co do głośnika to nie jest tak do konca ze moze byc uszkodzony. Masz BOSE z cd changer? zalezy od kodowania, przy innym kodowaniu radia tego bledu mozesz nie miec i tyle. Ja mialem BOSE i tez u mnie wywalal ten blad a wszystko dzialalo.
    Ty masz ustawione przednie glosniki pasywne a tylne nie aktywne..., pokombinuj z kodowaniem i zobaczysz.
    Feb 2014
    IE
    00
    03
    brilliant
    587
    Bartosz skad jestes? ja czesto graty wysylam z Polski do IE ....
  1. 180KM / QUATTRO / LOGI do kontroli
    Przez tomalla w dziale VAG-COM
    Odpowiedzi: 15
    Ostatni post / autor: 03-11-2011, 20:31
  2. Logi BAM quattro 225KM
    Przez mgb w dziale VAG-COM
    Ostatni post / autor: 13-09-2011, 08:53
  3. Logi 225KM Quattro 2000r - ocenicie?
    Przez d_matys w dziale VAG-COM
    Ostatni post / autor: 01-11-2010, 08:59
  4. Logi 1.8T 225 quattro
    Przez marini w dziale VAG-COM
    Ostatni post / autor: 12-09-2010, 19:29
  5. jak z quattro zrobić rwd???
    Przez DACEK111 w dziale Ogólne
    Ostatni post / autor: 05-10-2009, 16:13
